Question about Polaroid FLM-3232 Television
Get message "Adjust only in user mode"
Don't know why I can't adjust my color, hue brightness etc.
4 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: Video settings
hi there,
may i knw exactly the model that you have.
Posted on Feb 23, 2009
tvtek
  • 1284 Answers
SOURCE: adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Posted on Nov 11, 2009
gopakumarg43
  • 75289 Answers
SOURCE: When I go to the
Hello
Your TVs memory chip may be cnfused with so many commands. Just reset the set first. To reset it, enter in "Menu" and select All Reset option, highlight it and press OK. All settings will be reset to its original factory settings. color, contrast, brightness etc will come to 50% of total value. Now you can set them to according to your taste. OK.
Posted on Jul 20, 2011
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Samsung tv calibration
You're asking about the picture settings to this TV; I assume, and posts this solution. Just set it to user mode; in terms of picture; set the Color to minimum (0); Contrast = 70 ~ 75%; Brightness to 30 ~ 40%. In this way, just set a picture in Black/White first. If you see that the contrast or brightness level should be adjusted to get a good B/W picture, do it according to your viewing taste. After set this, advance the color; and compare the skin tone of a news reader at the studio.
In most cases, this must be the perfect adjustment. If you wish to get more details to picture, advance the Sharpness control. Do not set it too more. Less than 30% will be sufficient. If the broadcasting system is NTSC, you have to adjust the Hue too.
Apr 18, 2014 | Televison & Video
The picture on my Sony kp57hw40 has bluish hue to it. It is more visible when what you are watching is darker in color or lower in light. I have tried to adjust everything (color, brightness, etc,etc)...
I have first some information for you and then a possible solution.
A lot of these sets had problems with the 3 picture tubes---blue seems to be the most common--if you go to a unused video input and see anything other than Input 1 etc like blue background or even blue curved faint lines do not despair.
There is a fairly easy way to adjust this (not with the remote) I can tell you the procedure and it requires no parts and only moderate skill.
May I assist you here?
SD TECH
Oct 26, 2011 | Sony KP-57HW40 57" Rear Projection...
We got hit by lightening. The tv still works but the picture is color is affected- very light.Anything that can be done? Is there a degausser button?
Unless this is a tube set there is no Degaussing. Even the tube set have built in degausing when powered up.
LCD, LED, Plasma and projection sets are not affected by magnetic fields near the display like old tube sets.
You may be able to fine tune your colors through your OSD
Most sets allow consumer adjustments on brightness, color saturation, hue , contrast etc and are accessable through the On Screen Display or Setup option
Aug 03, 2011 | Televison & Video
I have Sanyo 42" flat screen LCD TV Model #DP42647. The color suddenly started appearing with pinkish hues. Any bright spot takes on a pink color and has no distinct features. I have tried to manually...
Hello; I am John at J. D. Electronics, Poland Maine. This problem is very likely caused by a defective LCD panel. This part is very expensive! Aprox $ 1000.00 from Sanyo . Obviously, that is more than the set sold for.
Oct 13, 2010 | Sanyo Televison & Video
Adjusting color/ user mode??
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Gray margin & not right hue
I just purchased a Sony SLV-798hf VCR secondhand. It did not come with a remote or instructions. Thus I'm unable to set time or use the record function. I tried getting a manual online and was unsucessful.
Aug 02, 2009 | Sony Televison & Video
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
How to adjust the 'hue' on a logik log19wh7
Try performing reset from the menu option.
if problem persists then get back to me
Regards
-Dileep Bradley
Mar 18, 2009 | Star Logic 17" LCD Monitor
Video settings
hi there,
Feb 23, 2009 | Polaroid FLM-3232 Television
Polaroid FLM-3232 Television Logo
200 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
