HP Pavilion M50 15" CRT Monitor Logo
Posted on Feb 23, 2009
Pavilion 6355 with pavilion m50 monitor model #D5258A
Problem I power up CPU I see the H/P logo screen then it changes to a black screen with blinking curser top left corner.
I can enter F1 Set-up screens
I cannot enter F8 fail safe mode
Any idea's ? Also if I press the select button the screen resolution is set to 720x400 70hz.
The CPU was purchased by my father new 75 years old he used it very little and left it unplugged several years and passed to my son for personal use.
It's basically a new unit love to resolve the problem.
3 Related Answers
Anonymous
  • 159 Answers
  • Posted on Oct 18, 2008
SOURCE: Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
nonontech
Lebanon Raingam
  • 4737 Answers
  • Posted on Nov 20, 2010
SOURCE: I just got a used
Have you tried the connection with Vga cable? If not try with a vga cable and setup the connection via VGA ports instead of DVI. If usb or audio connections are setup, please unplug them while trying this.
Also, when it goes "blank", look at the monitor very carefully and verify whether you see the images of the screen/desktop (though dark), if you can still see the images of the screen, then it's related to the inverter board, you'll need to replace the mainboard or replace the capacitors. You can refer the capacitors here (Click here, Page # 5), they are C801, C838, C851, C858, C868.
Before you replace them, check for damaged or bulged or melted (joints/connectors) capacitors on the board. You may also smell the burnt scent of the capacitors, sometimes it's difficult to detect with our eyes, only with meter/tester will work.
Also make sure the OSD isn't locked, press and hold down the Menu button until you see a message about OSD locked/unlock.
All the best.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Dec 21, 2010
SOURCE: I bought a new HP
You change it at the PC, the video resolution from your new PC is too high for the monitor to display.
Please read here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Model M50-C1. When on, why is there a black screen with sound?
this is not vizio tech support try a local repair shop
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
The system unit is started but the monitor is making black so, what is the problem , pleas tell me the solution
first check your monitor front power light blinking or not.
if it's blinking then then remove the signal cable to the cpu then check the company logo moving in the monitor.if it's moving means your monitor is OK.means no display in *********** board.
5helpful
4answers
LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
PC won't turn on, blue light flickering, green light flickering
check your monitor's connection, its power and VGA connection to cpu, the cpu may be good but you just see black screen bec. your monitor remained off. please bring it to HP service center for more help
The the width of the picture on my Monitor is reduced.
hi
you may click the right button of your mouse and go to the properties.From there you can adjust the screen resolution.
HP Pavilion Vs17 LCD MOnitor
an answer to this problem would be great because mine does the same thing...like blinks but monitor wont come on.
F1523 power light blink
resit your ram if the problem perssit then remove the video cable which is attaching to the cpu,check for any message in the monitor(monitor should be power on),if you are getting any message then your motherboards's display adapter has malfunctioned, send it for repair
2answers
Toshiba EA60 laptop wont go in boot sequance, its stop after toshiba logo and gives a black screen with blinking curser in top lef corner
Its probably not the BIOS but the board warping beneath the CPU Socket or similar.. Dont flash it (BIOS) or it will probably kill the chip. Let me look up the model number...
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
