Question about Garden
I have a Mastercraft Snowblower that wont run. The primer hose is disconnected and I dont know where it is supposed to be connected to
  • bibleman2002 Feb 25, 2009
    Thanks , I will try that
  • 181 Answers
There is a small tube on the side of carb that it hooks to,some times you need to pull the cover off the carb to see it.the other end goes to primer bulb.
Posted on Feb 24, 2009
Will not prime with primer bulb , can squirt gas in carb and get running then while running you push the primer button it chokes down the engine .
Does it stay running after you squirt fuel in the carb opening? If yes, then there may be a pin hole leak in the hose going from the fuel tank to the primer bulb and it is adding air to your carb.
Thanks
May 01, 2015 | Craftsman 675 Torque 190cc 21" Briggs ...
My snowblower wont start. primer button was loose and sounds like sucking air
primer buttons are cheap at your local lawn mower store.. go pick on up for your snowblower!!
Feb 21, 2015 | Garden
Not getting gas - wont start
carburettor dirty ,primer bulb has hole in it, or at worse the inlet from the carb.to the cylinder head cracked. hope this helps
Feb 12, 2014 | Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Mastercraft 4hp sat along time cleaned carburator and installed kit... still wont start
threw jets if the carb was stored with old fuel the jets could be plugged up as well as the needle valve can be stuck
Jul 03, 2012 | Garden
My yardmachine snowblower won't stay running. It starts if I pump the primer. Fires up than dies. The fuel line isn't clogged, but once it starts it seems like the throttle cable has no tension (floats...
empty the fuel bowl & tank. start out with fresh fuel for one. then get a new spark plug if it still dont start. as far as the cable thats another deal completely but it shouldnt cause it to stall out. but if it ran last year it will this year too. always run it empty for summer storage. its your personal choice if you use a summer storage lubricant.
Feb 09, 2010 | Mtd 22" Yard Machine Push Mower
Idles high and lower nearly konking out
Remove the air filter box and replace the gasket between the box and the carburetor
Sep 05, 2009 | Craftsman Garden
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
Snowblower Treads not turning
Check the steel axles that go through the plastic wheels.What happens is the axles rust and swell not allowing the track wheels to turn freely.its a problem overlooked by all the so called small engine repair shops.I have removed the wheels and sanded the axles to remove the rust.I greased the shafts and the wheels move freely.There is a provision on the wheel for a grease fitting.I carefully drilled the holes and with some strong waterproof glue thredhed a fitting in each wheel.
Mar 05, 2009 | Garden
Garden Logo
215 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
