Question about Sharp AR-153E Copier
  • 37 Answers
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Posted on Feb 27, 2009
After replacing the toner catridge in Sharp MX-B200 the toner lit light keep showing, how do i remove the showing lit light
The toner light is in the shape of a triangle. If your light is in the shape of a circle you need a developer change. Technician required to do this.
Aug 13, 2017 | Sharp Office Equipment & Supplies
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
Jan 28, 2016 | Sharp Ar 5316
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Unit powers up, but will not copy, and the light in the shape of a triangle is blinking
mos the toner light come on is just out of tonert likely is out of toner is it runs for ever and doent come to ready and finely
Jul 07, 2009 | Sharp AR 201 Copier
When i turn on the copier it is stuck on 10 copies and a light flashes to the left of the copy number. I don't have a manual. I don't know what the flashing light means.
If the light is a red light with a flash shape then the machine probably has a jam. Look for jams and once you have cleared any jams switch the machine off and then on again. It could be the toner light if there are about six red dots - in this case you need to add toner.
Jun 30, 2009 | Canon NP 7130 Black and White Copier
Hello Ms; The red Triangle lite means you need feed them toner, they are hungry !
Feb 23, 2009 | Sharp AL 1631 Copier
Will not print
Yeah thats an easy one. Your really out of toner, the density sensor is seeing a light development patch, and the firmware ( machine operating software) does not have a clue what to do.
I suspect, ohhhh about 99.99999999999999999999999999999999999 percent sure if you replace the toner cartridge your machine will warm up, set up in a minute or 2 and run like normal.
I have seen that time and again on that machine, The software sometimes simply doesnt know what to do with a light copy indication.
The out of toner sensor is a window type sensor, so if there is a little remaining toner on the sensor, yet the density sensor looking at the patch on the drum is light, the software has no clue what to do, so the machine runs, and runs, and runs, and runs...... A new toner cartridge is a almost 1000000000000000000000000000000000 percent fix.
Oct 16, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper feed problem
please check if the rubber roller that pulls the paper inside the machine check if it is clean because after long use this roller becomes so smooth ddue to dust and doesnt take in the paper , first clean it ,wipe with wet towel  try again
Oct 27, 2007 | Xerox 5305 Copier
Sharp AR-153E Copier Logo
324 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
