Question about Nextar I4-BC GPS Receiver
NEXTAR 14-bct KEEPS FREEZING UP.
The unit freezes; when powered off, then back on it returns to the frozen screen. Suggestion?
  • fklodner Apr 05, 2009
    I turn mine on and it freezes and will not load anything when I hook it to my computer it cant even read it it says usb drive created a problem any help
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Posted on Dec 03, 2010
  • Mark Dec 03, 2010
    EDIT* "you may need to *REPLACE the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again. "
Need SD card for: Nextar auto Nav. (GPS) with back up system. Item # 14-BCT
You can find SD cards for a number of different retailers. I have used Amazon before, you can also do a Google search to find probably 30 different vendors that have these cards. Average price is about 50 cents US per Gigabyte of size.
Mar 08, 2015 | Nextar GPS
My nextar 14-bct was not on for a long time then I charged battery a short time then when I was playing with it in house it went blank and now will not turn on
I have a nextar 14-bc and I was having similar problem and I found that the power in jack had a broken solder joint and when I thought it was charging it was not. I would not turn on until I discovered the broken solder joint inside on the power jack. I resoldered it and after it charged up it was up and working again. You might check on that.
Aug 19, 2011 | Nextar I4-BC GPS Receiver
Do you have an update for this gps and do you understand french? Nextar Item#14-BCT
we have no updates for any make GPS, to get updates u must go to the manufacturers web site and select support, if u are looking for Maps there will be a charge for them of around $120.00 USD
Jan 18, 2010 | GPS
Frozen Screen
Mine does this from time to time. I pull the SD map card, power it off, and hit the reset button while the unit is unplugged. These units are notorious for this. But then again, they're inexpensive. No receipt ... well, you're pretty much stuck with it. No receipt, no return or repair.
Sep 15, 2009 | Nextar X3-02 GPS Receiver
My x3t is frozen at logon screen help
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Please remember to rate my answer. Thanks.
Jul 02, 2009 | Nextar X3-02 GPS Receiver
Upates for nextar x4-t are there any?
Require updates for Nextar 14-BCT GPS
Mar 17, 2009 | Nextar X4-T Car GPS Receiver
Dont understand my gps
There are updates for a 14-BC is hat what you are looking for? If so follow the link. Hope this works!!!
http://www.nextar.com/frontend/gps_navigation_systems.asp?MODEL=I4-BC&subpr=&categ=
Jan 25, 2009 | Nextar I4-BC GPS Receiver
MY NEXTAR MA9336A1S IS STUCK ON THE NEXTAR SCREEN
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Apr 06, 2008 | Nextar MA933A MP3 Player
Nextar HGPS35
I found this on Nextar support site. These units **** lots of problems being reported by many users.
Q: It (GPS) freezes on the "loading" screen. Why?
A: Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Jan 13, 2008 | Nextar X3B GPS Navigation System
Nextar I4-BC GPS Receiver Logo
1,015 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
