Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Dirt Devil Feather lite bagless does not have suction from the base but the hose does
  • Anonymous Apr 03, 2009
    The hose and everything works, but the base doesnt **** anything... how do i fix this?
  • djsp934 May 03, 2009
    How do I get to the lower section of the vac to unplug the blockage?
  • 294 Answers
Based on your description the problem is a blockage in the lower section of the vac
Posted on Mar 01, 2009
Got a dirt devil upright I've cleaned out the Short hose extension hose also cleaned under bottom plate checked belt looks good don't see no holes or cuts in hoses no cracks in bagless container
Hello, Im assuming that your unit has no suction. If this is the case, it is still plugged. Run a stiff wire through all the hoses, starting at the on behind the bristle brush. Make sure all the bagless filters are completely cleaned.
Mar 30, 2017 | Dirt Devil Vacuums
Why is my Dirt Devil Vacuum Hose lacking suction?
I have a Dyson and was having a similar problem some time back. I found out these bagless systems still have a filter that picks up the fine dust to keep it contained. Find out where yours is located and beat the dust out of it really good or just replace it.
Hope this helps.
Mar 10, 2014 | Dirt Devil Vacuums
Suction
Try to take the screws out of the bottom UN screw the hose at the base usually one and see if that is clogged if it is clean it with a long hard object but all the screws back in and turn on should work
Jul 10, 2013 | Dirt Devil Featherlite Bagless Vacuum...
My dirt devil breeze shoots out dirt from vent
try cleaning the filters and clear out hoses, sounds like it has backed up inside, also if the filters aren't clean it can loose suction.
Nov 01, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
DIRT DEVIL FEATHER LITE BAGLESS WILL NOT JUST STOPPED WORKING
Hello, if the motor stopped working it might be the cord, but the motor is more like it, the bagless vacuum have more issue, and if you don't replace the hepa filters offen then the motor goes. If I can help future feel free to call 1561-848-3387 Thank you, Teresa. Clean sweep Vacuums
Aug 10, 2010 | Dirt Devil Featherlite Bagless Vacuum...
No suction through top of hose - HELP
disconnect the hose where it goes into the clear tube on top of the base.there will be a little flapper door there when yo take it off.open the door and take a coat hanger with the end bent over like a hook and pull the dirt clog out of there.but first take the dirt cup off and remove the filter,if its clogged with dirt you won't have any suction.try using the vacuum without the filter in the dirt cup.if you have suction then then thats your problem ,a cloggeds filter
Jul 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Suction when I vaccum the floor but not in the hose
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Jun 07, 2009 | Dirt Devil Featherlite Bagless Vacuum...
No Suction ARGH!
on the backside you will see a clear type of hose towards the bottom coming up the back.thats your intake hosethats whats clogged.you will see a connector that its connected to.on the connetor there is a screw,take the screw out and pull the connector away from the cack.take a coat hanger and bend the end so its round and work it down into the intake hose ,you should be able to push the clog out through the bottom.be carefull not to puncture the hose
Mar 15, 2009 | Dirt Devil Featherlight Bagless Upright...
Suction
make sure the brush roller is turning.if not the belt ie either broke or it might have come off the motor shaft.feel free to call me at 314-628-9153
Jan 26, 2009 | Dirt Devil Featherlight Bagless Upright...
Suction problem
sounds like you have a leak in the suction path
look for a broken hose or seal
May 21, 2007 | Dirt Devil M086700 Vision Bagless Upright...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
332 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
