Question about Panasonic SC-BT100 Theater System
SC-BT !00 Panasonic wireless speaker connection won't link
Illuminated indicator on the main unit is not displaying and connection to rear speakers is not operational.
Instructions followed to the letter, but as is usual with the manufacturers guide, it doesn't tell you in laymans terms how to activate the wireless speakers from the menu. I believe this is the problem.
If you go into the set up menu and go to the speakers set up - it only shows the right, left, centre and subwoofer on the screen. You need to go down to the box below these speakers and activate the rear speakers which are not shown. The wireless section will then light up w1/2 on the display at the front of the scbt100 - i had to call panasonic to figure this out and they advised me it was missing from the instructions!!!
Posted on Mar 07, 2009
Reconnect my wireless lg w95 receiver to my blue ray after it was unplugged
Wireless speakers connection
LED indicator of wireless receiver
LED Color Operation
Blue - The Wireless Receiver is receiving the signal of the wireless transmitter.
Red - The Wireless Receiver is in standby mode.
Off (No display) - The Wireless Receiver is turned off.
Initial setting an ID of wireless receiver
1. Connect the Wireless Receiver and the rear speaker (right, left) with the speaker cables.
2. Connect the power cord of the Wireless Receiver to the outlet.
3. Turn on the main unit and Wireless Receiver: The main unit and wireless receiver will be automatically connected. "MATE OK" appears in display window. Setting an ID of wireless receiver When the unit is manufactured, the ID is already set. If an interference occurs or you use a new wireless receiver, an ID should be set
again.
1. Turn on the main unit and turn off the wireless receiver.
2. Press and hold x (STOP) on the front of unit and MUTE on the remote control. "REMATE" appears in display window.
3. Turn on the Wireless Receiver. A new ID is set.
Nov 23, 2011 | Televison & Video
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
I got a panasonic sc-bt100 from sears used but i cant connect the rear speakers i think im missing a part do you need to put something on the dvd player so the rear speakers could work?
There should be a "module" that you slip into a slot on the back of the main SC-BT100 unit...this is the transmitter that sends the signal to the rear speaker unit. The rear speakers, while "wireless" to the main unit, are wired to the separate unit that should have come with your set-up.
Oct 02, 2009 | Panasonic SC-BT100 Theater System
Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Dec 29, 2008 | Televison & Video
Wireless speakers won't connect
You try upgrade the main set to 5.1 or 7.1 channel is it?
If the wireless is green light mean the main set is recognize the wireless.
You need to setup the speaker output from main set by "Setup" button on remote control.
Can refer Operating instruction manual in main set.
Nov 29, 2008 | Panasonic Home Theater System System
Panasonic SC-PT950 Wireless Speakers Question
It is pairing process again.
Inside the Main set operating instruction can help you solve it.
Aug 13, 2008 | Panasonic Home Theater System System
Panasonic wireless speakers
did you play with the settings on the remote? turn the pro logic on.
Aug 08, 2008 | Panasonic SC-PT960 Theater System with...
Can't get sound from the wireless subwoofer
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Jul 25, 2007 | Panasonic SC-PT1050 System
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic SC-BT100 Theater System Logo
645 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
