Question about Epson Stylus Pro 4000-PS InkJet Printer
I have an Epson 4000 which has a clogged nozzle
I have an Epson 4000 which has had a very stubborn clogged nozzle for months now . It is the magenta nozzle and I have tried many different type of fixes and cleanings and it is still clogged. What can I do?This is one of the original early 4000's(5yrs old) and I have produced many beautiful prints with it.
I live in Denver and have tried keeping the humidity up but that hasn't worked either
  • 2 more comments
  • gardunos Mar 21, 2009
    same printer same problem with the darn same nozzle!
    what is up epson?
  • Anonymous Mar 26, 2009
    Same problem, same cartridge
  • Anonymous Apr 03, 2009
    same problem, light magenta.  this is sooooo frustrating
  • Anonymous May 18, 2009
    same problem with the magenta ink ...has anyone found a solution???
    New Friend:
I had the same problem with an epson 4450 pro. I tried almost anything, wasted litres of precius ink. The problem was with the vacuum pump (the one used while cleaning - it removes waste ink from caping station) - one of it's tubes was broken. Replaced the whole assembly unit easily in less than one hour. I ordered the part directly from chinese manufacturer/vendor (125 USD, including DHL delivery).
It's difficult to diagnose but possible. For me it started with constant clogging especially of black and cyan - even every 5-10 A3 pages. After a longer pause in working the printer started to print yellow with magenta and cyan with black mixture, and after two pages it was printing clearly again. If you take out the right side cover to see the pump's outlet tubes there should be dirty ink flowing in both of them during cleaning/power cleaning. For me only one was transporting the waste ink. This was the cause of all my headaches when it comes to this printer, luckily for couple months now it's fine. Hope this helps someone.
Posted on Dec 28, 2012
I've cleaned the capping station as recommended by R A smart my supplier of sawgrass ArTainium inks but the nozzles are still clogged, this started a few days ago when the yellow started showing showing magenta in it's print out.
I'm at a loss as to what to do next as the print outs are now looking worse.
Posted on Mar 17, 2011
I have an Epson 4000 which I started using new in Sept 2004 and my magenta is clogged too. I've gone through 2 maintenance tanks trying to clear it, (and LOTS of ink), but the magenta is still blocked. I even tried this: http://www.youtube.com/watch?v=3NR8g4qUAJc trick but it didn't seem to work. I hope you have better luck.
Posted on Feb 08, 2010
  • 1 more comment
  • kendraart Feb 08, 2010
    I am now going to try a similar solution called puddle cleaning where you leave the print heads to soak for an hour or overnight. I hope it works. It is posted here: http://forums.dpreview.com/forums/read.a... Good luck!
  • kendraart Mar 20, 2010
    It is now over a month later and my magenta is STILL blocked! I have even soaked the printhead in Fantastik for 3 days and left a bowl of water in the paper tray to increase humidity. It didn't work. Now I have gone through over $1000 worth of ink and maintenance tanks (I'm on my 3rd maintenance tank change since the magenta stopped working). Today I even downloaded the Printer Service Utility 2 from Epson and downloaded and installed a newer version of the Firmware which is supposed to help with the cleaning process, but my magenta is still not coming out at all.
    If anyone has a solution for this, please let me know!
    Thanks!
  • kaila0228 Dec 13, 2010
    It looks a lot of users has same issue specifically on magenta.
    We better bring this case to the court. Epson just sell the nice looking printer over the world but don't care after all. I have same trouble on magenta. Printer was sent to local epson authorized dealer for repair and each time I needed to spend more than $500.00. It's ridiculous. Epson sucks!!!!
Maintenance request error code 4000 for Epson stylist pro 4900
HI,
MAINTENANCE REQ - 4000 - It detects twice in a row that all the nozzles are clogging.
Check the video to know how to clean the nozzle to get ride of error 4000
How to clear nozzle clog on your Epson wide format printer from PRO...
www.electro-medical.blogspot.com
Mar 04, 2013 | Epson Office Equipment & Supplies
Printer acts like it is printing but it spits out blank paper. Ink supply shows up as good. What could it be?
If the printer has not been used in some time ink may have dried in the print head. Unfortunately Epson have a non-removable head, so it can not be cleaned without a kit available for purchase. If you have installed new cartridges make sure any air tags have been removed. these are usually on the top of compatible cartridges or on the bottom of Epson brand cartridges.
The kits are available online, Search for Epson head Cleaning Kits and you will find one.
I hope this helps
Regards GM
Apr 21, 2011 | Epson Stylus C88 InkJet Photo Printer
I just replaced my ink cartridges for my Epson Workforce 600 printer and the magenta and yellow colors do not print. The status shows that both are still full of ink, but when I do the nozzle check,...
Try "Nozzle cleaning" and if the problem persist, try "Deep nozzle cleaning". Try them only once or else the ink will run out very quickly.
If the ink cartridges are not genuine Epson, remove them and buy genuine cartridges. If needed, repeat the procedure with them.
Non-original consumables very often clog the printhead.
Aug 07, 2010 | Epson WorkForce 600 All-In-One InkJet...
When printing a red line appears about every 8mm through the all of the page i am useing a epson rx630 fred
It means some nozzle not perfect. If you check nozzle, there is missing lines for some nozzle. Example : Print blue color ( 100% cyan + 100% magenta). If some point of cyan head is clog, the output will be shown that at some lines just show magenta. It repeated. Yous said every 8 mm, so, you must print it at best photo quality. If you have print at best photo quality, and lines still appear, it must some nozlle badly clog. Try do head cleaning, wait for 30 minutes. Check Nozzle.
Jun 25, 2009 | Epson Office Equipment & Supplies
Epson Stylus C86 - prints faint magenta even though ink levels are in a normal printing range - does not print anything or a barely seen magenta line during nozzle check and heading cleaning
You probably have a slowly worsening clog building up in the Magenta nozzles. It's also possible that your ink is reaching its end of life which, given the age of the C86 is entirely possible, especially if you are refilling or using a CIS sytem with your printer.
If it's a clog issue you can try soaking the parking pad with a mildly ammoniated cleaning solution (original Ammonia windex is good for this) or even distilled water. Leaving this with the printhead parked above it allows the solution to wick up into the nozzles and break down any clogs in the printhead.
If the problem is ink age though you will probably want to carry out the solution above AND replace your ink with a fresh solution. A CIS will need a thorough flush to remove any algae and cloggation residues before you use it again or you will just reintroduce the problem.
Hope that helps.
Martin
May 27, 2009 | Epson Stylus C86 InkJet Printer
Epson 9600 Magenta problems...
sounds like a problem with the damper/cleaning unit.
You need to clean the "pads" under where the print head parks.
Turn off power. open front cover. push it cutter (blue) and slide printhead to the left.
You will see a pad in there. this is the cleaning area. Remove and clean. Also next to this is a wiper. it is vertical and needs to be washed with some rubbing alcohol.
try these and get back to me.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson R310 printer
The magenta and black nozzles are probably clogged. What does the nozzle check pattern show? In no magenta and black, run a head clean or three.
Feb 12, 2008 | Dell 922 All-In-One InkJet Printer
Epson Stylus Pro 4000-PS InkJet Printer Logo
1,721 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
