Question about Kenmore 43142 Front Load Washer
No power to Kenmore HE2 Front Load Washer
Have a Kenmore HE2 Front Load Washer. It is not receiving any power. Power to outlet but no power to machine. When you depress power button, nothing happens. Also, interior light does not come on. Please advise. Many thanks!
  • fixer444 May 11, 2010
    Check your washer's plug, maybe a wire's loose, or the fuse has blown........
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
What could be the reason that my Kenmore HE2 Plus Front Load Washer won't start?
Hi, Could be the door switch, make sure the door is shutting completly then try to start.
Aug 15, 2014 | Kenmore HE2 Plus Front Load Washer
Code 20
Possible that the program controller has hung up. Please remove power for some time and try again. Also check if the inlet and the outlet drain has jammed or the motor is free to agitate.
click this link for tips to remove pump: Removing pump
Jun 25, 2012 | Kenmore HE2 Plus Front Load Washer
It is showing 12 minutes but will not allow me to cancel, start, or do anything. We had a power surge and wonder if that has something to do with it.
That is quite possible..... I would unplug the power cord from the Outlet. Wait about 5 minutes and replug the washer and restart push cancel and then restart your wash. Good Luck hopefully the power surge didn't cause any permanent damage to the control board.......
Feb 18, 2011 | Kenmore HE2 Plus Front Load Washer
My kenmore front load HE2 plus wont turn on.
Check that it is plugged in.
Check that the breaker is on on the breaker box or that the fuse is still good.
See if there is a seperate circuit control switch for the washer outlet.
Make sure the door is fully closed.
Check the door close sensor or switch is operational.
Aug 16, 2010 | Kenmore HE2 Plus Front Load Washer
How do i reset my kenmore he 2 washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Jan 03, 2010 | Kenmore HE2 Plus Front Load Washer
I have an HE2 Elite Kenmore front load washer. I
Sounds like a control board issue. Not much else for you to do but wait
Eric
Nov 19, 2009 | Kenmore Washing Machines
No manual ...no power- how do I work this machine? I'm able to lock/unlock it
THIS IS THE ONLY THING YOU CAN DO
Check that the unit is plugged into a working outlet and for
blown fuses.
This must be done by a THECHNICIAN SPETIALIST
Unplug washer or disconnect power.
Check continuity of line cord and line fi lter.
Check harness connections to CCU.
Plug in washer or reconnect power.
Check the touch-pad/LED assembly by selecting different
cycles and changing the modifi ers and options available to
confi rm the touch-pad/LED is responding.
Unplug the harness to UI and check with a DVM or VOM on
Connector UIP3 if correct voltage is present.
Pin 1: -5V
Pin 2: 0V (connection to Line or neutral is present in
normal operation).
Pin 3: -12V
If voltage not present and CCU is powered correctly (line
cord and linefi lter has continuity) the CCU is broken.
Disassemble the UI and check harness to UI and
Interconnection on UI between Center and Right Board.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 43142 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
