Question about Cuisinart TOB-50 Toaster Oven with Convection Cooking
Toaster oven door will not close completely.
Cuisinart classic toaster oven door will not shut completely.  Has anyone found a solution to this problem? I am trying to complain, I actually want to fix it. Thanks!
  • 1 more comment
  • Anonymous Mar 06, 2009
    Toaster oven door never closes all the way. In addition, the handle broke off. Cooks great, but a real piece of #*$&!
  • Anonymous Mar 15, 2009
    The door will not close completely and therefore my TOB-50. doesn't function properly. I am competant with electro-mechanical equipment but I cannot even get this one open for inspection. (I don't have a shop manual.) I suspect that a closure spring has broken or come loose.
  • tomw273 Mar 22, 2009
    The toaster door does not close. You have to 'play' with the door several times before it closes completely/
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Posted on Mar 31, 2009
  • Kevin Moriarty Mar 21, 2012
    This was brilliant and exactly what I needed. One thing I would add is that optional step 8 can be done without removing the side panel. If you just open the toaster oven door, to the left you'll see the bracket that pulls the door closed. Take a small metal file, like from a fingernail clipper, and ever-so-slightly file the notch of that bracket. That's all it took to fix my door.
    Nonetheless, I'm glad I went through the process of the removing the side panel so that I could understand why this was happening.
Open the door and spray a little WD-40 into the vertical slot on the left near the hinge. Wait a day for solvents to fully evaporate before using.
Posted on Jul 02, 2009
  • Catra7 Jan 15, 2011
    This worked great on the door of my Hamilton Beach toaster oven 31136C.
    Thanks auntmipgh!
    New Friend:
Take a wire hanger and bend (just with your bare hands, if you can) its plane on both shoulders creating a kind of a spring which will hold the door from above. (In my case, I baked a slightly too large a dish in my 16 lit. Kennedy toaster oven, after which the door, fruatratingly, would not shut up completely.)
Posted on Oct 14, 2014
Fantastic! Thank you. I followed those steps to remove the cover, very easy, perfect. But then instead of messing with the two existing screws holding the limiting bracket, I did something else. Noticing the bracket would "rock" left & right on its flimsy metal, and noticing it was only held down along one side, I drilled a hole closer to the bracket's middle and put a steel rivet through it. So now it is held to the front by two screws and a new rivet. Works great, hope it holds!
Posted on May 14, 2009
How do i register my product online
On-line registration for Cuisinart Canada is here:
https://www.cuisinart.ca/warranty/index.php
Simply complete the on-line form with the required inforamtion and click register at the bottom.
Mar 26, 2011 | Cuisinart CBK-200 Toaster Oven with...
Door does not close
After 3 years of perfect service, our toaster oven's door stop closing easily. After reading the internet and trying to contact Cuisinart for a solution I was stumped and frustrated. Someone on the internet mentioned using wd-40, but I didn't want the smell when I toasted! I try cleaning the metal arm that held the glass door using an alcohol pad and that actually helped a little! After thinking about something to lubricate the door are with that won't smell awful and hopefully won't catch fire -- I decided to try olive oil! I took a little, very little on a paper towel and rubbed the metal arm a few times -- It worked!!!!!!! The Door now closes with the greatest of ease! and doesn't smell awful when you toast, so far it has not caught fire. Give it a try! I love to give it 4 starts, but Cuisinart support didn't have a solution... I'm sure even if I suggest to them my fix that won't share the info, but use at your risk! I am certainly not responsible for any mishaps that may occur if try my fix, but worked for me.
Dec 31, 2010 | Cuisinart TOB-50 Toaster Oven with...
Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Jan 29, 2010 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Where can I purchase the three knobs for the TOB-30? I cleaned all the ink off of them.
You can get them from Cuisinart at 1-800-726-0190 - the availability varies -sometimes they have them in stock, sometimes they don't
Jul 20, 2009 | Cuisinart TOB-30 Classic 1500 Watts...
Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Cuisinart: toaster part of toaser broiler oven does not work
Definitely a defect - return to store if possible, or call Cuisinart - it has a 3-year warranty.
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart TOB30BW Toaster Oven with...
Warning tone?
Have you tried turning the function button to off? This has worked for mine.
Aug 18, 2008 | Cuisinart TOB-30 Toaster Oven with...
Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
May 06, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart TOB-50 Toaster Oven with Convection Cooking Logo
2,536 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
