Question about Vizio GV42L 42 in. LCD Television
Vizio 42" LCD with Screen problem
Recently our Vizio TV started to act wierd. Sound, chanel changing and power is all normal. When the unit is turned on the screen images are normal, but the color of everything is like looking at a photo negative. After leafing the unit on for 5 minutes the problem went away. Then ten minutes, then 20, 30 and now no matter how long you leave it on, it never corrects itself. I'm pretty handy with small electronics. Im just trying to narrow down my first move. I can get a replacement video controller card for about $65, but from reading a lot of the postings here it seems like the main board is a likely culprit. They are about $120. Any suggestions would be appreciated.
  • 718 Answers
Find the LCD Controller board (TCON). Disconnect the cables from it to the LCD panel. Carefully re-connect them. Make sure the cable is properly positioned in the connector. You may have to do this several times to get it work. The flat cables are a problem.
Posted on Feb 23, 2009
Vizio 42 in. Black screen no sound. TV will not turn off. Is this worth trying to fix?
Look on for Parts. Look on power supply for Bad Capacitors they will be swollen or vented on Top.
Oct 18, 2011 | Vizio 42 in. LCD TV
I have a vizio 42 model vp42hdtv and the screen is dark red I have sound
VP42 HDTV Will not power up. Changed power supply board and power cord. Still nothing
Apr 12, 2011 | Vizio 42 in. LCD TV
My 42in Vizio LCD has sound but no picture. Screen starts blue when it turns on then goes to black with only sound.
Make sure in the back of the TV the "picture cords" or A/V cables are properly fitted.... Hope this helps :)
Jan 08, 2011 | Vizio 42 in. LCD TV
My sanyo 42in lcd has just started acting up. I changed the batteries in my remote and now my tv turns on and off on its own and will not show a picture or sound. I cannot even change the channels. The...
Remove the batteries from the remote then see if the set returns to normal and you can use the buttons on the tv. If after the batteries are out and the set is still acting upreturns back to normal then the remote is bad, I have seen cases where something has been spilled on the remote and no one was told.
Dec 10, 2010 | Sanyo 42 in. LCD TV
VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from (you can also use This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Jan 13, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
May 28, 2009 | Vizio VU42L 42 in. LCD TV
Vizio 32" Plasma Freezes up
A lot of picture freezing issues are signal based. Check the signal strength and quality.
Jul 24, 2017 | Vizio L32 32 in. LCD HDTV
Have a one foot by one foot black box in lower right corner of tv.
thats called PIP aka picture in picture on your remote theres a way to turn it off or change the chanel of it what it is its like another tv but with no sound and you see another chanel or video input on it and you can switch it on the remote
Mar 27, 2009 | Vizio GV42L 42 in. LCD Television
May be a bad power supply, which is a common problem with these units.I have a GV42L 42" manufactured in march 2007. It works perfect except the screen has a fracture on it. The warranty is voided because we damaged the screen. I can sell this to somone who has a good screen but needs boards or speakers, etc. Or I will buy your tv that has a good screen but damaged boards in it.
Aug 13, 2008 | Vizio GV42L 42 in. LCD Television
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV42L 42 in. LCD Television Logo
495 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
