Question about Casio FX-115ES Scientific Calculator
How to enter variables
I have a casio fx-115ES and i have some problems that require variables.. example.. 2x3(cubed)-686.
how do i enter this into my calculator to solve?
  • Casio Master
  • 7,993 Answers
When you press the key between X^2 and log it gives you a template where you enter the base of the power (bigger rectangle) and the exponent (the smaller raised rectangle) . Using the 3 cubed exemple is not good because base and exponent are the same.
Exemple :15 cubed.
Press the key with an X with a small raised rectangle. The cursor blinks at the left side of the raised rectangle. Enter the exponent (3). Then use the left arrow to move the cursor to the base. Enter 15 and press [=]. The result is displayed as 3375 or in some other equivalent form (with a power of ten.)
Hope it helps.
Posted on Oct 03, 2009
  • k24674 Dec 06, 2009
    With variables:
    In what follows physical keys are represented inside square brackets [ ] while the SHIFTed or ALPHA keys are inside parentheses. Exemple [ ) ] is a left parenthesis and [ALPHA][ ) ] displays X; [X^2] calculates the square of a number, while [SHIFT][X^2] calculates the cube.
    2[ * ][APLHA] [)] (X) [SHIFT][X^2] (X^3) -686
    OOPs [ ) ] is a right parenthesis.
How to enter a variable in a fx-115ES PLUS
To type in X , press [ALPHA] [)], to type in Y, press [ALPHA] [S<=>D].
Aug 16, 2014 | Casio FX-115ES Scientific Calculator
I forgot how to do linear regression on casio fx-115ES. Example: (1,2), (3,Y), (5,6). How can i solve for Y in casio FX-115ES?
Press [MODE][3][2]. In first column enter known x-coordinates (1 and 5), in second known y-coordinates (2 and 6). The solution you are looking for is in form Y=A+B*X where X=3. Your calculator computes A and B after you enter data. To calculate Y (which is equal to A+B*3 press [SHIFT][1][7][1][+][SHIFT][1][7][2][*][3][=]. The result should be 4.
If I helped you, please rate my answer :)
Sep 07, 2011 | Casio FX-115ES Scientific Calculator
Solving linear equations in 3 variables by matrix method in casio fx-115ES
Press key Mode, first select option 5:EQN (by pressing key 5), then option 2: a_nX+b_nY+c_nZ=d_n (by pressin 2).
Now input coefficients from equations in table (each column is for one variable), just type in number and press =, then use arrows to move to another cell.
Sep 02, 2011 | Casio FX-115ES Scientific Calculator
How to find cube root
Use the cube-root function, which is the shifted function of the square-root key (third row, second column). For example, to find the cube root of 8, press
SHIFT [cube-root] 8 =
Jul 09, 2011 | Casio FX-115ES Scientific Calculator
Hi there. I'm using Casio FX-570ES scientific calculator. I would be glad if you could guide me as to how to obtain derivative of a polynomial expression e.g. y=12(x^2+6)^5
Here is an example. Instead of SIN(X) insert your polynomials.
The syntax of the command is
where function is the expression you are differentiating
x is the value of variable x at which you are evaluating the derivative, and tol is the tolerance (the error) you are willing to tolerate in the result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral]
To enter the symbol x in the expression you press [ALPHA][ ) ]
To enter a comma you use [SHIFT] [ ) ]
To enter a power of 10 in the tolerance use [x10^X] key
Example : Calculate
The key sequence is as follows
[SHIFT] [Integral] 3 [ALPHA] [ ) ] [X^2] [-] 5 [ALPHA] [ ) ] +2 [SHIFT] [ ) ] 2 [SHIFT] [ ) ] 1 [x10^X] [(-)] 12 ) [=]
DO NOT confuse [SHIFT] [ ) ] which enters the comma and [ALPHA] [ ) ] which enters the variable X.
May 28, 2011 | Casio FX-115ES Scientific Calculator
What are the parts of casio calculator My manual is 75 pages. I can email it to you. Please put Casio FX-115ES as the subject. Awaiting your response.
fx-115ES User's Guide
About this Manual
• The MATH mark indicates an example that uses Math format,
while the LINE mark indicates Linear format. For details about
input/output formats, see "Specifying the Input/Output Format".
• Keycap markings indicate what a key inputs or what function it
Example: 1, 2, +, -, !, A, etc.
• Pressing the 1 or S key followed by a second key performs
the alternate function of the second key. The alternate function is
indicated by the text printed above the key.
• The following shows what the different colors of the alternate
function key text mean.
If key marking
text is this color: It means this:
Press 1 and then the key to access
the applicable function.
Press S and then the key to input the
applicable variable, constant, or symbol.
Purple (or enclosed Enter the CMPLX Mode to access the
in purple brackets) function.
Green (or enclosed Enter the BASE-N Mode to access the
in green brackets) function.
• The following shows an example of how an alternate function
operation is represented in this User's Guide.
Indicates the function that is accessed by the key
operation (1s) before it. Note that this is not part
of the actual key operation you perform.
Keycap function s
Alternate function
Jan 19, 2011 | Casio FX-115ES Scientific Calculator
How to store and recall on fx-115es
To store a value into one of the variables A, B, C, D, X, Y, press SHIFT [STO] and the variable name.
To recall a value from one of them, press RCL and the variable name.
Oct 12, 2010 | Casio FX-115ES Scientific Calculator
How do i convert a degrees/minutes/second problem using the Casio Fx-115ES calculator? Can you provide an example? Thanks ZH
Use the key above the ENG key to enter a value in DMS form, ending each portion with the key. To convert it to decimal, press SD once (or twice if you get a fraction the first time).
Example: sine of 12 degrees 15 minutes:
sin 12 *** 15 *** =
where *** is the DMS key.
Sep 25, 2010 | Casio FX-115ES Scientific Calculator
Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
Apr 17, 2009 | Casio FX-115ES Scientific Calculator
How to enter problems on calculator
Jun 26, 2008 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
500 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
