Question about Microsoft Xbox Console
Taking an Xbox apart.
How do you take the cover of an Xbox console off? There are no screws that are visible. Are there clips of soe type?
    President:
  • 2,653 Answers
The screws are hidden underneath the feet and there are a few under some labels too. Just use a flat blad or a butterknife to pop the rubber feet off.
The hidden ones underneath the labels are easy to find just poke your screwdriver around until you hit a softspot.
Posted on Feb 23, 2009
    Problem Solver:
  • 15 Answers
You will need a small torx screwdriver for the screws, which are about 3 inches long. You can see where the screws are here. Follow the instructions on http://softmodxport.com. It has great information.
good luck
cgman
Posted on Mar 18, 2009
I have taken this xbox apart once before but did not get very far. What type of tools are necessary to repair this type of Xbox 360? I would also like to update the CD/DVD drive on it. Any hints or ti
Most of this can be taken apart with a screwdriver . The case is a little tricky. You will notice from the side...where the case is split, there are tabs on the inside that you need to press. I poked a small screwdriver through the vent holes to press them and get the box apart.
Oct 04, 2012 | Video Game Consoles & Games
How can i get into my xbox360 without having to buy the tools
if you mean taking out the screws, your going to have to borrow a trox type screwdriver or go buy one not much else you can do other than bust the case apart... sorry.
Jul 19, 2009 | Microsoft Xbox 360 Elite Console
No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Apr 25, 2009 | Kenmore 22642 Top Load Washer
Xbox Disc Tray Loose
If you are comfortable with taking apart your system, I would advise taking the case off and then finding the dvd-drive, removing the case on that and simply tightening the screws on the tray. Don't tighten them too much, but make sure they are snug. Then test to see if it still wobbles and it should be fixed. If you are not comfortable with taking apart your system you will need to find a repair shop that can do it for you.
Please rate, thanks!
Mar 31, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Taking apart the xbox 360
You actually have to order a special kit to open it, Safely anyway. Another way is by brute forcing with a hammer and screw driver and basically any tools you can find that would be helpful.
Feb 04, 2009 | Microsoft Xbox 360 Console
The cartridge is stopped by a protruding piece of plastic.
I took mine apart today, there's a silver cover on the left that needs to come off to access the final screw, and I can see of no way of separating the two halves, as there's a tab that protrudes down from the cover which connects with the bottom half. I ended up levering it off. This gives access to the panel and button circuit that unclips and unplugs, then undo the last screw, then there is a clip that needs to be held back to get the top cover off.
Hope this helps,
Paul.
Nov 19, 2008 | HP Photosmart 7450 InkJet Printer
ONN 0V002 VAC CLEANER
everything clips together on a dyson putting together is easier than taking it apart there will be a clip that you cant see
Jul 04, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
to play copied dvd's ( i think thats what you typed ), you will need to do a few things, including taking your xbox apart, and connecting it to your computer. You will also need to flash your dvd drive.
Quick NEED list:
1. SATA Cable
2. SATA Card
3. torx screw driver
4. torx 8 and 10 bits
5. Flash / Pen drive (USB)
To do this, your computer has to have some kind of SATA port. You can buy a SATA card for $25.00 at your local computer hardware store. Also make sure you pick up at least an 18 inch SATA cable. Now once you have both of these, then you will have to take your x-box apart.
Dont know how to take your 360 apart? Click on the link below
http://www.llamma.com/xbox360/repair/Xbox-360-Disassembly.htm
Heres a good tutorial on how you flash your dvd drive too:
http://venomousfire.blogspot.com/2008/02/how-to-flash-benq-xbox-360.html
hope this helps
Feb 10, 2008 | Microsoft Xbox 360 Core System Video Game...
Hey man
You need a hex screw driver to take out the screws (8 I believe).  Why do you want to take apart your 360?
Oct 27, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
112 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
