Question about Sansui HDLCD3210 32 in. LCD TV
Setup 32 inch sansui for digital reception
Our tv has digital format included but we are having trouble getting our
local channels to come in. How do we scan for digital setup?
  • 718 Answers
1) Connect your signal source - either CABLE or ANTENNA.
2) Go into your menu and select your signal source to match.
3) SCAN in the channels. This will give you all channels available.
Your User Manual will give you all information.
If you are on cable, you may have to check with your supplier to see if they carry local stations.
Posted on Feb 23, 2009
How do i hook up a 32 inch Sansui TV to an antenna
After you connect the antenna cable to the TV go into the setup mode and on the tuner line change it from cable to air. Then do an automatic channel search and you're done.
Oct 22, 2015 | Sansui Televison & Video
I csnnot get Auto Scan to run - it is finding no channels
ensure the set is adjusted to receive the type of channels that are broadcast in your area. By this I mean that if digital is broadcast ensure the tv is setup for digital reception.
I assume that you are using an antenna/aerial. Ensure that this correctly installed and is functioning, there may be a facility on the tv to check the reception via a swr meter of some kind, basically a utiliity that registers that an aerial is bringing in some kind of signal.
It cannot be anything else, if the tv is setup for the local broadcast type and the aerial is connected the signals should be found unless you have very bad reception due to environmental conditions.... in which case you may have to invest in a reception booster/signal amplifier.
Oct 13, 2015 | Element Electronics Televison & Video
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Nov 28, 2009 | Televison & Video
Channel change
Go into the menu and do the automatic channel scan. It will go and find all the locally available channels, including analog.
Jun 13, 2009 | Sansui DTV2760 27" TV
Trouble getting digital on a sansui 27"
your antenna is not strong enough to receive
digital or your in a area where large
structures are blocking the reception.
you could try turning the antenna slightly
and rescanning .
Jun 12, 2009 | Sansui DTV2760 27" TV
Do you need set top box for digital for SANSUI SAN3201-what is HDTV channel for?
yes you need one for clear correct reception
Please don't forget to rate me "FIXYA"...thank you!
Mar 19, 2009 | Sansui HDLCD3210 32 in. LCD TV
Sansui HDLCD1908 not recieveing Digital channels
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
Jan 06, 2009 | Sansui 19 in. LCD TV
My new TV is set for cable. I do not have cable, I have an anten
Sansui TV's come from the factory set for CABLE. If this is a HDLCDVD320, you will have to go into the menu to change the signal type to AIR, then run the automatic search to program in your channels. Their free customer service line is 800 289 0980.
I hope this helps.
Dec 28, 2008 | Televison & Video
Sansui HDLCD3210 32 in. LCD TV Logo
833 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
