Question about Yahoo Messenger
Error 81003005 I am trying to connect the yahoo messenger since yesterday and I 'm still getting the same 81003005 error message. Never had this problem before!! Any idea on how to solve it? Please!!!
  • gumc Feb 25, 2009
    Thank you very much Fardinfard!
    President:
  • 392 Answers
[Solution #1]
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
My solution is good only if you have set your proxy server previously in your Internet Explorer. I've noticed this behaviour since in our school, I need to set the proxy server to access the internet. But at home, I don't need to. So when I am at home, this is the normal situation I encounter when I forget to unset back the proxy settings.
On the other hand, the other way around should work. What I mean here is, if you connect to a network that has a proxy server, you need to setup the proxy settings in order for you to use their internet services. Thus, access to yahoo could be established.
[Solution #2]
One area to look also if the proxy is not the one causing the problem, you can check if you have your DNS Server address(es) set, which - in case you have changed your network, can't be accessible to the new network. Thus, it can cause this error.
So, you may unset the DNS Servers (Go to Network Properties >> General Tab >> TCP/IP Properties >> General Tab >  Obtain DNS Server address automatically) and try logging in your YM.
[Solution #3]
If the above solutions does not go well, this last one might be the savior. Instead of constantly banging your heads with those re-logins and reconfigurations, you can track back your YM version and replace it with an old version instead. I did this and it works for me well. I had before a version 9 Yahoo Messenger and when I replace it with a version 8, the problem was solved. This should be your last resort if the previous won't work. Remember also to be patient. If it bugs you, don't bug down... bug up!
source: http://www.stephenhaim.com/resources/yahoo-messenger-81003005-error
Posted on Feb 24, 2009
Why i see error number 81003005 in yahoo messenger?
This message appear probably because of your computer proxy software by default change your connection properties.
Solution is
Open you internet explorer
  • click tools>>>Internet option>>>connection tap
  • Under Dial-up and Virtual Private Network setting
  • Double click your current internet connection that you are using now
  • Make sure that under Proxy Server, the ‘Use a proxy server for this connection’ isUNCHECKED
  • Now back to connection tab
  • Click LAN setting
  • Click OK>>OK
  • Try to logging to your Yahoo messsenger again.
Jul 25, 2009 | Yahoo Messenger
I m not able to login messenger show error 81003005
my yahoo messenger can not work there is some thing wrong
May 18, 2009 | Yahoo Messenger
81003005
try two things.
Go to internet options in your explorer. Go to Connections tab and click open lan settings make sure your proxy server is unchecked. than click ok and try again.
If not
this will work.
Uninstall messenger(i know pain in but), and download the new version http://messenger.yahoo.com/
save it instead of just running the program, install it and try it that way.
That is usually and update or proxy error.
Good Luck let me know.
Feb 15, 2009 | Yahoo Messenger
Error 81003005
I solved the problem by logging into the web yahoo messenger (http://webmessenger.yahoo.com).  Then I was able to log in with the normal messenger client.  I was having the error 81003005 on multiple computers.  After logging into the web messenger, the yahoo client worked on all my computers
Dec 31, 2008 | Yahoo Messenger
Error 81003005
Yahoo! servers are down for maintenance, the only fix would be to wait.
Dec 30, 2008 | Yahoo Messenger
Errror 81003005 wont let me sign in to yahoomessneger
ok, in my case i remembered I tried using a proxy on internet explorer and forgot to put it off, so the proxy connection was still on even though the proxy was dead.
It now a proven fact to me that internet explore settings are linked to yahoo mess!
so make sure your internet explorer is working ok without proxy:
good luck =)
Dec 07, 2008 | Yahoo Messenger
Please try again a little bit later (81003005)
hi,try the solution posted on this site:
http://stephenhaim.com/resources/yahoo-messenger-81003005-error
please give me a good rating if solution works for u.
Thanks for using FixYa.
Nov 22, 2008 | Yahoo YHT-630 System
Yahoo Messenger Logo
225 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
