Question about Maytag Neptune MAH5500B Front Load Washer
Replace coin box locks
Where can i find locks to replace the old locks or keys to unlock the locks that are on the machines now
  • Anonymous Feb 26, 2009
    i have the same problem. i had a repair guy run off with the keys to the coin box. and i am not having much luck in finding a solution. my next step is to contact a locksmith. perhaps they can help me out. at least maybe they can pick the lock on the existing coin box so i can remove it and get a new one. or best of all maybe they can install a new lock. the lock looks to be a very simple and straightforward. i'll keep looking for solutions and let you know if i come up with anything. glen
    Problem Solver:
  • 5 Answers
I just called Great Lakes commercial for my old Maytag locks. About $20
616-531-8810 I spoke to Sue.
Posted on Mar 03, 2009
Container for coins how to remove.
Coin operated commercial washer? Need the key to open the coin box. No key... You have to drill the lock out. Not easy. It is theft proof steel. You need a diamond tip drill bit.
Has done this as a service repair guy. I will say that it might not be easy. Has to get the right drill bit if you needed open with in 30 minutes.
Oct 25, 2017 | Washing Machines
I have a huebsch coin laundry but when I tried to open to empty the coins the key doesnt work and that's the only key I used all this time . what could be the problem thanks
If someone has attempted to break into the machine, they may have damaged your key mechanism. Try lubricating the key, inspect the key for damage also, gently feel as you try to turn the lock for a section of less resistance... Replace the lock if you get it open. If all else fails, you may have to spend the day drilling out the lock, hardened steel is difficult, but not impossible to drill...
Apr 25, 2016 | Washing Machines
Canon 2120 photocopier
Is the 123 orange with a box around it? If so, the copier is looking for a key counter to be installed. The copier may have had a coin machine attached to it or a pass key to lock the copier up. From what I remember, this is a very, very OLD copier, there is a clip under the control panel that needs to be jumped to make the copier run with out the key option. Good Luck
Jul 16, 2013 | Office Equipment & Supplies
Washing machine wont come on but i check the plugs and the push button are okey . you know any other parts that needs to be replace ? thank you.
If this is a kenmore front loader (boxy type made by frigidaire), the button must be
depressed for several seconds. The second problem with this model is the "coin
mechanism" cam must be in the correct position to operate the machine. If someone
puts in coins two times without starting, it can get out of sequence with the timer.
If you have a key, open coin box and move the metal arm back until the cam advances
to just before the big dip. (with the unit unplugged). The next cycle will allow the
arm to drop and engage the microswitches. If you don't have a key put coins in the
slide mechanism as though you were going to start the machine and
depress button until machine starts, this will reset the cam to the correct position.
Hard to explain but if you look at the coin mechanism, it will become obvious.
If you need a new mechanism it is called the "start mechanism" for front loaders.
Hope this helps.
Apr 16, 2011 | Kenmore 3.1 cu. ft. Coin Operated Extra...
SMALL LOCK APPEARS IN CONTROL BOX AND WONT ALOW
That lock icon indicates a locked door, and if you can open your door with it locked, your door lock will need to be reset. Your instruction manual should have your reset procedure listed in back. But if your door IS locked, you will need to manually drain out the water before it will open.
Mar 18, 2010 | Samsung WF328AA Front Load Washer
Can I simply replace a battery in my jimmy car door unlock/lock
On the side of the key FOB is an indentation to put a coin. Pry apart with coin then replace battery. Long as the battery hasn't been dead to long it should still work on the vehicle.
Mar 15, 2009 | 1995 GMC Jimmy
I have a maytag coin operated washer and dryer. After the last service call the repair man ran off with the keys to the coin boxes. How do i get new keys to the coin boxes? Alternatively, how can i remove...
Unfortunately if you do not have a good locksmith, you will have to drill out the locks and replace them. Not a cheap solution by any means.....If I can help further, I am here.... Eric Campion
Feb 27, 2009 | Maytag MAT12CSD Top-Load Coin Operated...
I just bought a house that included in the sale a Maytag Coin-op Washer and Dryer. The coin box on each contains a key. How do I disable the need for putting coins in the washer and dryer so that I can...
  1. purchase a coin insert and blank the slot that coins fit in, then the slide will slid in without coins, just acting like a button, if you examine the slide you wil notice that there are plastic inserts in unused coin slots, any maytag commercial dealer has them.
  2. replace coin slide with 'free operation' converter, which is just a button plate that pushes the striker on the timer switch
  3. take top cover off and just push the striker on the timer, (this is NOT) a recommended option, 220v is enough to spoil you whole day)
Oct 24, 2008 | Maytag Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
899 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
