Question about Apple iPod MA446LL/A MP3 Player
My 30g ipod is stuck in the restore mode. i follow the instructions on how to restore it, and everytime i plug it into the computer, it says it needs to be restored. how do i get it out of the restore mode.
    Scholar:
  • 92 Answers
Try this out: And let me know the status
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Then try restoring the ipod using Itunes...
Posted on Feb 26, 2009
My ipod 30g dont work only show www.apple technical support
The problem *might* be solved by resetting or restoring your iPod. Otherwise, you'll probably need to take the iPod into an Apple store to see what's wrong.
Here's how to reset your iPod:
  1. Turn on the iPod, and make sure it's unlocked (no red is showing by the switch at the top)
  2. Press the "menu" button (at the top of the circle) and the "select" button (middle of the circle) at the same time and hold them down for at least 10 seconds, until you see the Apple logo on the screen
Here's how to restore your iPod:
NOTE: this will delete all music, etc. from your iPod
  1. Plug your iPod into the computer
  2. Open iTunes
  3. Click on "Restore" (on the "Summary" tab)
  4. Follow the onscreen instructions.
You'll need to resync all your music etc. to get it back on the iPod after it's been restored.
If your iPod does not show up in iTunes, use these directions to put it into disk mode: http://support.apple.com/kb/HT1363
Then try the restore directions again.
Hope this helps!
May 09, 2010 | Apple iPod MA446LL/A MP3 Player
MY IPOD IS STUCK IN THE ITUNES SCREAN
Do you mean this screen:
Your iPod touch is currently in DFU mode. You must plug it in to your computer and restore.
For detailed instruction, click here but you don't have to do the steps in putting your device to DFU mode, you should proceed to the part where it says: "... restore to 3.1.2..."
For more iPod touch . iPhone tips, click here.
Feb 11, 2010 | Apple iPod touch
What can you do if you forgot the passcode to your ipod touch
If you cannot remember your passcode, then you can place the iPod into recovery mode and restore the iPod.
To do this:
1) Turn the iPod touch off.
2) Hold down the Home button and plug the iPod into the computer it was last synced with.
3) Release the Home button when the iTunes image appears on the iPod's screen.
4) When iTunes recognizes that the iPod is in recovery mode, follow the onscreen instructions to restore the iPod.
Note: Restoring the iPod may cause you to lose some data currently on the iPod.
If you cannot unlock the iPod after this, you will need to call Apple Customer Support.
Nov 21, 2009 | Apple iPod touch
My itouch is disabled how do i unlock it
Plug the iPod touch into the computer that it was last synced with.
Once iTunes recognizes the iPod you should be able to unlock it with your password.
If you do not remember your password or you still cannot unlock the iPod, then you should try to restore the iPod.
To restore the iPod:
1) Turn the iPod off.
2) Hold down the Home button and connect the iPod to the computer it was last synced with.
3) Continue to hold the Home button until the iTunes symbol appears on the iPod's screen. The iPod is now in recovery mode.
4) After iTunes has recognized that the iPod is in recovery mode, follow iTunes instructions and restore the iPod.
If restoring the iPod doesn't work, then you will need to call Apple customer support.
Nov 14, 2009 | Apple iPod touch
Ipod stuck on Connect to Itunes
    Complete a Regular Restore
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the Internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch.
  8. Complete an Advanced Restore
  9. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  10. Plug the iPod Touch into your computer.
  11. Power on the iPod Touch.
  12. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  13. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  14. Return to the above section and follow those steps to restore your iPod Touch.
Sep 25, 2009 | Apple iPod touch
My iPod touch went all white then after I reset it the screen just went black and wont turn on now. Please help me!
  2. Connect to the internet and install the latest version of iTunes from the Apple website.
Want to reboot my ipod 16 gb touch
To reboot you ipod all you need to do is just turn it off and turn it back on.
If you mean restore your ipod follow these steps
  1. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  2. Plug the iPod Touch into your computer.
  3. Power on the iPod Touch.
  4. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  5. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  6. Return to the above section and follow those steps to restore your iPod Touch.
Sep 24, 2009 | Apple iPod touch
My ipod 30g turn on then showing the apple then crashes
Put you ipod in disk mode
Press and Hold the Menu and Center buttons
when the apple appears quickly switch to
Press and hold the Center and Play/Pause buttons.
If it goes into Disk mode, connect it to your computer and
Restore your ipod to factory settings.
Relaod your music
Warning: Restoring your ipod will delete all your music and content and reload the operating software.
Apr 25, 2009 | Apple iPod nano
I plug an ipod video 30G in my computer, and my computer cant detect it1 but my ipod is charging, and also d code i forgot it
You will want to force the iPod into disc mode (while unconnected from computer) and restore using iTunes on your computer. Below I have posted a step by step for both parts of the resolution. If for any reason this does not resolve your issue, or you have difficulties with any part; please do let me know. I am eager to be of assistance.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. The screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
How to restore iPod (ARTICLE NUMBER HT1339)
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Apr 14, 2009 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
155 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
