Question about Saeco Odea Giro Plus Coffee Maker
Frothing valve leaks water when not in use
Saeco Odeo Giro plus leaks water from the frothing valve when frother is not being used. it leaks when you are just brewing an espresso shot. what is the remedy?
    President:
  • 1,618 Answers
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Posted on Feb 27, 2009
Steam wand boils water but does not make any froth
Making froth with a steam wand is an entire technique. Also depends if it has a panarello or not
Jan 06, 2015 | Saeco Odea Giro Plus Coffee Maker
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
Can I replace the grinder in my saeco odeo giro?
yes see the next steps. and fix it. God bless you
  1. Unplug the unit from the electrical receptacle.
  2. Remove the pot and basket. Remove or tape closed the water reservoir lid.
  3. Turn the appliance over and remove all screws that secure the case halves. Lift off the case to expose the heating element and controls.
  4. Inspect the control cavity to determine if the solution is simple: disconnected wire, debris, etc. If so, fix, reassemble, and test. Otherwise, continue with the next step.
  5. Use a DVOM to test the HEATING ELEMENTS and the switch, thermostat, and timer .
  6. Replace any defective parts or decide to replace the appliance, as appropriate.
  7. Reassemble the appliance and reinstall the pot and basket.
  8. Fill the water reservoir approximately half full, then plug in and turn on the coffee maker to test its operation.
Oct 15, 2012 | Saeco Odeo Giro Automatic Espresso...
Water not pumping out of coffee machine
It seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
Feb 17, 2010 | Saeco Talea Giro Espresso Machine
After using steamer for milk frothing the red light comes on and cannot get esspresso to brew and no more steam or hot water comes out of the frothing nozzle, the water level is fine in reservior, beans in...
The tap valve is leaking inside the machine needs new seals.If moisture is escaped and hit the printed circuit card on the tap, the machine will stop you from doing other functions.
Feb 05, 2010 | Saeco Odea-Giro Espresso Machine
We've descaled and the light still appears on the saeco odeo giro
Have you done as described in the manual:
Press the hot water button for
6 seconds to deactivate the
descaling light.
Jul 18, 2009 | Saeco Odea-Giro Espresso Machine
Saeco Odeo Giro Plus dripping steam wand
I don't know any of the suppliers in the UK, but yes the problem can be fixed at home, it is very easy to replace the steam valve, just make sure that you get the complete valve(body and tap rod). Try this site they might ship the parts to you (saecoparts.com)
Jun 09, 2009 | Coffee Makers & Espresso Machines
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
I purchased a second hand Saeco Royal Professional coffee machine and the frother does not work. When I press the button all I hear is a pumping sound but no suction what so ever. Also when I use the...
try inserting the frother in hot water its probably block and for our water everytime you whant steam open vale boiler start to boil water let the water drip into the tray wait untill steam come out pierre
Jan 10, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro Plus Coffee Maker Logo
1,000 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
