Question about Tivo DirectTV Remote Remote Control
Where is the tivo button located?
My remote has all the writing rubbed thru wear and tare. Can you tell me how to locate the tivo button.
    Scholar:
  • 98 Answers
Generally, the Tivo button is at the very top of the Remote, in the middle. It's the larger button that *isn't* round, but more of a square shape.
Posted on Mar 26, 2009
Tip
DirectTV RC65 Programming
TIVO DirectTV RC65 Remote Control Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
Remote control code required for virgin TiVo & 50 inch blaupunkt TV combo
I have just managed to do this. I cannot tell you the code as I had to do it manually, but this is how I did it.
point the remote away from the TiVo and hold down the clear button and the to button until the free light flashed twice.
type in the code 0999 and the light will flash again. Then point the remote at the to and press and hold the channel up button. You will now scroll throw all the codes.
it will take about a minute but eventually the to will go off. When this happens release the channel up button and hold down the green on button to try turn the tv on with the TiVo remote.
if it comes on press ok and this will store the code. If it doesn't come on, use the blaupunkt to remote to turn the tv back on and then keep holding down the channel up button to scroll through more codes. When the to goes off again release the channel up button and try turn it on with the TiVo remote. If it works this time store the code by pressing ok
for me it took two attempts to turn the to on but eventually it worked on the second code
Nov 29, 2014 | Blaupunkt Car Audio & Video
Codes apex tv
There is a default code search to find the code that works with your remote. It is 0999.
There's a helpful link on TiVos site:
Locating Remote Control Programming Codes
Aug 06, 2014 | Tivo C00210 Remote Control
Why doesn't TiVo follow button commands from remote? Batteries have been changed. No obstructions. Tried Global remote re-set.
put on new batteries with correct polarities and try.
one more method is get a AM radio receiver and switch it on tune it to lowest frequency,and now bring your remote near it press one button after another,you should hear some noise when each button of remote is pressed if not open the remote clean all contacts with Iso-propyl(IP) alcohol with good surgical cotton.it has to work .
Aug 04, 2014 | Tivo Televison & Video
NEW SAMSUNG CABLE BOX TIME WARNER &TIVO SERIES 2
the IR is located next to the power button and you will have to select pioneer as your cable box brand and it will work fine
Jul 28, 2010 | Samsung Televison & Video
Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
Jun 11, 2009 | Tivo Series 2 Remote Control
Need to program a directv philips series 2 remote
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
Dec 20, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Tivo DirectTV remote problem
I have a Tivo black peanut remote. Can this remote be reprogrammed to power a different receiver?
Dec 07, 2007 | Tivo DirectTV Remote Remote Control
Tivo DirectTV Remote Remote Control Logo
150 people viewed this question
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
