Question about IBM NetBAY 09N4291 8-port KVM Switch
09N4291 APEX KVM when pressing 0 (zero) it produce a / (slash). Must reset all the time.
  • michel_pouli Feb 23, 2009
    The problem was that nobody ever save the configuration for the KVM. So it seems that when switching to one console to another, the last keyboard configuration was keeped.
    Because that's an IBM AT3200 keyboard, it does'nt seems to have a numeric keyboard. No marking on the keys, no num lock button.
    But you can trigger the numlock.
    Since one of my server had the numlock On, when I took a look on that one, then change server it keeped that configuration and suddenly all 0 became a slash. Resetting the KVM return to normal for those servers without numlock On.
    When I saved the KVM configuration, after a reset of the KVM and while on a server with NumLock Off then I only have the problem with one server. And no matter how many time I reset the KVM, it stay that way. I check every keys on the keyboard and realize there was a numeric keypad. Turn that off and save the KVM configuration again.
    Everyting is ok now.
HOW DO I GET MY IOGEAR 4 PORT SWITCH # GCS614A TO SWITCH BETWEEN MONITORS
You have to press Ctrl, Alt, Shift one button at a time in that order... then press 0,1,2,3,4 (0 will autoscan for active ports). Press Esc or Spacebar to exit autoscan mode. :)
Jan 29, 2011 | IOGear Computers & Internet
Not powering on
check your power cable low power could efect the proformance. try changing it to a more powerful power cord or a different power outlet
Nov 07, 2009 | IBM NetBAY 09N4291 8-port KVM Switch
Eurovox
Use the remote and:
Menu>Config>DeleteData>DeleteChannels>OK>OK (pin = 0 0 0 0)
It will say please wait for channel delete
Use the remote and:
Menu>Config>DeleteData>Factory Default>OK>OK (pin = 0 0 0 0)
It will say please wait for factory reset and after 10seconds you will be returned to the scanning screen.
Sep 03, 2009 | StarTech.com StarView SV211K 2-port KVM...
Reset the password to default on an edimax ek16ro Need to reset the password on the KVM,
According to the user manual, the device needs to be sent in. The user manual can be found at:
http://www.edimax.com/images/Image/manual/KVM/EK-08-16RO/EK-08_16RO_M.pdf
  • Note: If you are not familiar with the operation of OSD menu, please don’t change the password – i.e. keep default eight zero (00000000) value.
  • Otherwise, if you have set the password and unfortunately forget the password, you need send it back to your distributor for resetting the password.
Jan 27, 2009 | IBM NetBAY 09N4291 8-port KVM Switch
Whats the number 2 get in 2 putin up the codes
this should work .
press menu.
press 1570.
Nagravision screen look down list making sure EMU set to ON. press ok ,
code screen provider ID ntel.5401. tw5A01.cw.5C01.
key No 00
key data change the codes storing each code entered. Go back to 00 and press right 01 and change these codes saving each code. Exit.
ntel.
0.3F B8 36 62 72 E5 E2 76
1.35 5E D6 40 6E AA 99 41
tw
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
cw.
0.D4 A3 5D EB 7B F3 69 59
1.27 77 A1 FC 8F 9D 34 76
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Scrambeled Channel
you need to put in new codes.
1.menu.
2. 1570.
3. Nagravision press OK.
4. 00 tab.
change keys to new codes saving each code you enter, go back to the 00 tab press right till 01.
change codes to new saving each code you enter then exit out .
NT.
0=3F B8 36 62 72 E5 E2 76
1=DB 7A A2 F2 4B 12 7E 59
TW
0=3F 32 37 03 D0 73 84 84
1=F0 83 35 E5 28 40 49 B2
cw
0=D4 A3 5D EB 7B F3 69 59
1=01 54 B4 A5 79 46 CD AA
Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
Box super starview
has any one got any information for putting codes in starview 3 super
thanks 817440.
Nov 05, 2008 | StarTech.com StarView SV211K 2-port KVM...
How to set up Compaq Series 4110 8-port KVM Switch & select computer
The Compaq 4110 KVM switch was actually manufactured by Apex which is now part of Avocent. Your switch is Compaq's rebranding of the Apex/Outlook EL-80DT from Avocent.
The key to display the KVM switch menu should be PrintScreen. Here is a link to the user manual:
ftp://ftp.avocent.com/public/product-upgrades/Outlook/EL40-80DT/OL_DT_UG.pdf
Your answer seems to be on page 34.
May 30, 2008 | Compaq 242695-001 8-port KVM Switch
Compaq 8-port kvm switch firmware
HP Parts supposedly still stocks the EPROM for this model, so you can try to order it from the HP Parts Store. Check for part 340579-001.
Mar 13, 2008 | Compaq 242695-001 8-port KVM Switch
KVM switch control
APEX switches are manufacturer by Avocent and rebranded by Dell, HP/Compaq, IBM, etc.
The keystrokes should be CTRL-CTRL (Hit control 2 times). Some Avocent switches also use ALT-ALT or SCROLL-SCROLL.
Jan 12, 2008 | IBM NetBAY 09N4290 4-port KVM Switch
IBM NetBAY 09N4291 8-port KVM Switch Logo
1,091 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
