Question about Pentax K1000 35mm SLR Camera
Loud grinding noise when I "****" the film.
I recently found this camera in my father's closet, he gave it to me.
I loaded the film the first time, and it worked fine, but the negatives came bakc blank.
I asked my photography teacher to load the film properly.
Now when I move the arm to advance the film, it makes an awful grin ding noise.
I don't know a whole lot about cameras as you can tell, but I am very intrested in film and want to do this correctly.
Please, please help me.
    Scholar:
  • 185 Answers
Kyle_walsh,
does this noise happen with film loaded or all the time?
this could be a broken gear or the take-up spool is slipping. with the film door opened advance the lever and check if the take up spool is turning. if not turning then a gear is broken. if the spool is turning then the spool is slipping.
there are no new parts available for the K1000, however some camera repair shops have good used parts that can be used.
the take-up spool was one of the very few weak parts of the K1000, you can make a temp. repair if you want.
on the take-up spool push down lightly on the gear like wheel and rotate the spool you should see a hairline crack under where the film is inserted. check both sides. if you find the crack put a very small amount of super glue on the crack using a tooth pick or similar tool. this works 80% of the time.
if you take or send your K1000 to a camera repair shop get an estimate first.
Posted on Feb 23, 2009
My camera will begin to turn on but the flash settings won'
is it the auto film load feature on this camera doing this ??? it maybe the type of film u use , most auto loads are not to forgiving on the different types of film , I had this problem as I still use a film camera a lot for infrared photos (digitals too expensive ) and have found that its real picky on whos film I use to weather it works or not , as on some brands of film it just goes on and on and never stops , the only way I can save it from being ruined is to tell it to rewind , it then sucks all the film back into holder and I try it again ,sometimes works sometimes no
Aug 17, 2016 | FUJIFILM instax mini 8 Instant Film Camera
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
We have an amana ac. It recently started making a loud noice from the furnace closet which is upstairs. 2 different ac repair companies came out but could not find anything wrong. The line to the outside...
Hello, if the line is freezing there is either a airflow problem or low refrigerant charge. If there is a loud noise most likey the bearings on the motor or the blower wheel is bad and causing a lower amount of air passing over the evaporator coil and thus the freezing of the suction line.
Jul 15, 2012 | Heating & Cooling
Hello, I have not been using my Pentax zX5n for a while. Recently I decided to use it again and was surprised to discover that after loading a new batteries that it would not start. Actually after loading...
Have the old batteries leaked in the battery compartment ? Also, when you removed the previous film, did you set the camera into rewind mode ? If not, you have probably damaged the winding motor beyond economical repair.
May 08, 2017 | Pentax ZX-5 35mm SLR Camera
Can't get the film to catch trying to load.
I found a manual online that gave the information.
Aug 02, 2009 | Minolta Dynax 404Si Film Camera
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Camera inoperable
According to the manual found here:
http://www.pentaximaging.com/files/manual/ZX50.pdf
It says, "If the film is not loaded properly, 'E' on the LCD panel blinks, indicating that the film is not loaded properly. Open the back cover and load the film once again."
Dec 15, 2007 | Pentax ZX-50 35mm SLR Camera
HELP HL-R5067W LOUD GRINDING/VIBRATING NOISE
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Dec 13, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Pentax K1000 35mm SLR Camera Logo
202 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
