Question about Microsoft Xbox 360 Console
Xbox 360 I want to connect my x-box360 to my linksys router but the IP address always fails, any ideas ?
  • 3 Answers
Go on the linksys site and then click on the router you have. They all have default IP addresses. Maybe you are typing in the wrong IP address? Also, some of your settings may be wrong so check some XBOX router FAQ's online for other help. I also have a linksys router, but it works fine on my XBOX. You might want to try directly hooking up your XBOX to your modem, maybe it's not detecting the router if you have wireless?
Posted on Feb 25, 2009
Xbox 360 ics apipa
you need to set static ip's for the xbox 360 and the lan that is on the pc, easy to bride the two connections on your computer, then set static on the lan that the 360 is plugged in to, example:
360's static settings:
ip: 192.168.1.14 sub: 255.255.255.0 gateway 192.168.1.1 ------------------------------- computers settings:
ip 192.168.1.15 sub 255.255.255.0 gateway 192.168.1.1
Feb 05, 2009 | Microsoft Xbox 360 Console
Running two xbox live 360
Hello there.
A router shares your internet connection with local computers and devices on your local area network. Microsoft's xbox live requires a connection to your IP address on a certain port. This will be a problem when using 2 xboxes so what you would need to do is contact your Internet Service Provider, explain that you are using a router and require an additional Static IP Address.
Once they provide you the details for this, you can manually set up one of the xboxes with the static details your isp has given you.
This should stop the 2 xbox conflicting over connecting to the internet, as they will be running on seperate ip addresses.
Hope this helps.
May 19, 2008 | Microsoft Xbox 360 Console
XBOX 360 not connected to wireless connection on Linskys WAG54G2
You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
Jan 06, 2009 | Computers & Internet
Trying to hook up my lynksis wrt54gs to get online with myt XBOX 360.. have no idea where to start or what to do.. please advise -Zac
go to the router then configure the port forwarding option put the ip address of the xbox 360 to in the router then you get it
Jan 02, 2009 | Linksys Wireless-G WRT54G Router
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Xbox 360 to Linksys wireless modem...
OK I think the easiest way to connect the xbox to the linksys, is if you configure your XBOX to have a static IP address, because the xbox will not have to pick an IP address every time you connect to the internet using the Linksys router and will not have conflicts with other PCs on your house, if you have any. What the linksys does is to convert your Public IP addres into a Private IP address, so example if your ISP gave you an IP address of: 209.235.205.30 that is your IP address for you, then the Linksys converts that number (NAT) into a private IP address so it can be share with many computer inside your house using a single Public IP address. The Linksys always transform it into 192.168.1.?=any number between 1-256 thats the defaults IP address from the manufacturer but you can change it if you want. Ok enough info about NAT or IP jeje.
Where going to use the default IP addres for an easier setup.
First: On your XBOX 360 dashboard go to SYSTEM, then Network Settings, then Edit Settings, then choose the option manual, here put the IP address= 192.168.1.33 (if 33 doesn't work use another numer like 20 or 45 just pick a number between 2 and 250) ; Subnet Mask = 255.255.255.0 ; Gateway = 192.168.1.1; DNS options put Automatic. And see if it connects. If it doesn't work just post it here, any problem that you have.
Aug 22, 2008 | Microsoft Xbox 360 Console
Router and xbox 360
in the DMZ zone of your router, it has to be capable to accept incoming connections .
to access your router..192.168.1.1 in internet explorer >>> go >>> it will gonna ask your passwor d and user name(by default they are admin) >>> go to application & gaming...select DMZ...DMZ Hosting -select enable..and tipe your IP address in the form below.
You can find your IP address in Status >>> select Local network >>>> DHCP client table >>>> and you'll gonna find your PC name and IP address in there.
Jan 19, 2008 | Linksys Wireless-G WKUSB54GS Kit
Microsoft Xbox 360 Console Logo
67 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
