Question about KLH R7000 Receiver
KLH Receiver Shorting Out
I've had my KLH receiver for probably near 8 years now, maybe a little less. Recently it's having a problem where after playing for awhile it will send out a loud pop through my speakers and turn off. It seems to be random, not after a certain amount of time because it happened 3 times in one day in a period of a couple hours but then I listened to it all day for probably 5 hours plus with no problems.
  • 4,234 Answers
See if you can spot a pattern to the failures. I suspect that it is heat related. In the time that the unit ran all day, I suspect that the volume level was lower. Am I correct? If so, then either there are poor solder connections which are being effected by heat or there is a part that is defective. Are there any other symptoms or does the unit just shut off? If you attempt to turn it on, will it play for a while? If you can solder, look for solder connections that look grainy or have rings and resolder them.
Keep us posted on your progress,
Dan
Posted on Feb 24, 2009
I have a KLH subwoofer which is connected to my reciever and speakers with speaker wire. It is not connected to an outlet. It has recently started making a buzzing/rattling type sound. Do I need to take...
Yes, probably, if you aren't capable of repair yourself. However, IMHO, a replacement will probably cost less in the long run. I have a KLH passive subwoofer myself. I wouldn't pay for any repair if it failed. Replacements are far too inexpensive.
Aug 18, 2014 | KLH Audio Players & Recorders
What are the buttons for
Hello
There is no free download. If you want to get its manual, there are some paid download sites; and hereby send it to you. Just try them.
www.tradebit.com/...php/131951826-klh-r3000-r3100-quick-manua...
homeaudio.englishmanuals.com/stereo.../klh/r3100_2-188736.htmlCached
printfu.org/klh+receiver
Feb 12, 2012 | KLH R3100 Receiver
STATUS OF MY ORDER?KLH R5100 AUDIO VIDEO RECEIVER?
Sorry. I haven't the user manual for KLH 5100 audio video receiver with me now.
Nov 01, 2011 | KLH R5100 Receiver
I DON'T KNOW ALL FEATURES AND CONNECTIONS FOR MY KLH R5100 AUDIO VIDEO RECEIVER.I NEED A MANUAL FOR MY RECEIVER.
I don't have the manual with me. I found KLH R 5100 with user manual in the following link. Tray to contact them.
OK
http://www.ebay.com/itm/KLH-R-5100-Receiver-Hi-Power-/250902259353
My KLH 5100 System worked fine for nearly a year. Very suddenly the remote control seems to have no effect on the unit. It doesn't switch it on, or off, or change the volume...nothing. I changed the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 08, 2011 | KLH R5100 Receiver
We had this receiver for a little while and we just bought new speakers. (Bose) It worked for a little while and then it shuts itself off. We moved the speakers to another receiver and they work fine. The...
Probably a shorted amp. Turn it on with no speakers hooked up, if it still says check speakers,it will need service (output transistors and a couple of resistors) A few times I've seen them only need soldering of an emmittor resistor.
Jan 19, 2009 | KLH R5100 Receiver
Klh home receiver problems
It is not a fuse problem, when a fuse is gone does not start at all.
It is probably the final amp circuit, there is a faulty IC in there that overheats after few seconds and the unit goes off by itself.
Sep 11, 2008 | KLH R3100 Receiver
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
KLH R7000 Receiver Logo
220 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
