Question about Stanley Bostitch F21PL Nailer
BOSTITCH 2IN1 VENTS AIR AND WILL NOT FIRE
PULL TRIGGER AND THE ONLY THING THAT HAPPENS IS A SMALL PUFF OF AIR COMES OUT OR THE AIR NAILER AND IT DOES NOT DRIVE THE NAIL.
    President:
  • Stanley Master
  • 1,388 Answers
Your nailer is one of many bostitch nailers that use the TVA6 trigger valve. With time, this triggering valve will wear and act as you describe. Some TVA6 valves have a green plastic pin that wears and becomes shorter. (some have a metal pin) The safety foot and trigger can also cause problems. Try the following to determine the problem:
Remove the roll pin that holds the trigger in place to expose the tva6 valve pin. Remove the nails from the gun and connect airline. Place the nose of the gun against wood or hard rubber and with a very quick motion depress the trigger pin all the way in. If the gun fires then the problem is that the safety and the trigger are not depressing the tva6 pin all the way in. Check for worn parts and replace as necessary.
If gun does not fire remove the head from the gun and check headvalve for worn orings or very tiny scratches where orings contact surfaces. Use a magnify lense to check surfaces if necessary. Use very fine sandpaper to remove scratches (300 grit). Lube orings with silicone paste (looks like vaseline, sold at Lowes in plumbing department it is used to lube faucet orings) and re-assemble. This will make your nailer regain lost power.
Finally, when the tva6 valve fails, air will leak out valve at a high rate, however as the valve wears it will become troublesome if you have a plastic pin. To replace remove trigger then remove roll pins that retain valve. Use a thick glove to catch the valve as you connect to air supply. Use caution because it will come out with force. You may want to reduce pressure to gun when you do this. Good luck with your repair and email if you have question.
Posted on Feb 24, 2009
I have a bostitch n62fn finish nailer that wont fire. when i pull the trigger, air comes out of the trigger assymbly. the gun is not jammed, and is receiving correct air pressure.
this may sound stupid but are you pushing it against the wood when pulling the trigger. it has a safety switch on the front so it will not work just by pulling the trigger.
Nov 12, 2011 | Stanley Bostitch N62fn Finish Nailer Parts...
Stapler losing air around trigger is this a o ring problem?
The problem is most likely the trigger valve. P/N FA205BA1 any Bostitch dealer should be able to get it for you. Its a complete cartridge that slids into the gun frame, unfortunatly you can't just change the o-rings.
Dec 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
When I pull trigger air is escaping around the trigger and nailer will not engage
you need a new trigger valve assembly, there is an o ring that has split. Contact Bostitch for a replacement part.
Oct 08, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer gun. How do I adjust the depth the nailer shoots the brad nails into base boards? I see that their is a dial on the back...
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Jun 12, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Not shooting
Trigger Valve needs replacing. Part Number is FA205BA1. The valve comes with instructions, its a pretty easy fix. Any BBostitch dealer should be able to get you one.
Mar 11, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
My Bostitch SB 2in1 nailer will only on occation nail all the way into the wood. For the most part the nail will bend over before it goes in, which damages the wood. I spend more time tying to pull out...
I ran into this problem many times. Don`t use the Bostitch brand nails. Use the generic or other name brand. You`ll notice the generic one`s heads are just a little bigger and the driver blade won`t run down the side of the nail!
Thanks,
Jeff
Jan 05, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Must pull the trigger every time to shoot a nail, should be able to hold trigger and tap where i want the nail.
On some models the contact fire is not available. There is a flap that is under the actual trigger. When you press the safety in, it engages this little flap which allows the trigger to be engaged. As soon as the safety comes up this little flap falls back down disengaging the trigger.
There is an optional trigger assembly that you can put on this nailer. You need parts 174299 and 174300 to make this gun a contact nailer.
Sep 10, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Fires like a machine gun without pulling triger. Close call
Bostitch N60FN finish nailer:
I replaced the o-rings and reassembled now when I put air to it the driver does not return and when I pull the trigger I get a "puff" sound.
Sep 07, 2009 | Stanley Bostitch N88rh Framing Nailer...
Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Jan 05, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley Bostitch F21PL Nailer Logo
662 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
