Question about Chef's Choice 678 Cordless Electric Kettle
Unit will not turn on
Water was dripping from the handle which had become disengaged from the metal and I believe that shorted out the unit
  • 137 Answers
That's a pretty safe bet, I would NOT try to use this appliance. DANGEROUS, DANGEROUS
Throw it away, it is not that expensive as the treatment for restarting your heart.
Posted on Feb 24, 2009
Our Giagni Andanti model LL800-BN bathroom faucet drips after water is turned off need to know how to make an adjustment to stop drip
Turn the water off. Remove the handle, usually has an Allan wrench screw on it. Take out the stopper unit and clean it. When you are done tighten it as you can without stripping it, Out it all back together and it should work. Sometimes you need to replace the washers or internal unit itself, but try this first.
Apr 16, 2014 | Giagni LL800 Andante Open Trough 1-Handle...
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
Slow drip from refrigerator water dispenser
Sounds like a defective water control valve W10408180
Change that out and I believe you will be fine. If you have questions please let me know, Thanks Sea Breeze
May 03, 2012 | Whirlpool Refrigerators
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
Faucet installed 9/94 and still looks like new. But in past few days have begun seeing slow drip running down from one of the inner metal flexible hoses when faucet is on and for maybe 5-10 min after water...
Try tighten the hoses, if this don't work the seal in hose connectors may need replaced, very simple and cheap to replace. over time the hot water will wear down the seal it will go bad with pressure and water period. It's a good thing to change these all while you are there.
Jan 18, 2010 | Kohler K-12176-PB Fairfax Single Handle...
I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Krups XP2070
if the water is leaking from the back left side of the unit then the seal/valve to the expresso water container is lose and leaking. you can either go the warranty route or open the back up and tighten the two screws holding the seat/valve in place.
Jan 03, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Collecting water on top of house boat from air conditioner
Thess units are designed to discharge the condensed water onto the roof under normal conditions. HOWEVER you should be able to have a sheet metal person make up a drain pan to fit under the unit.
You would ten need to add an additional gasket between the drain pan to roof and drain pan to A/C unit. The drain pan could have a hose connection attached to the drain pan. Try it, you might like it.
Also you may have to get longer screws to tighten down the A/C from below.
Jul 22, 2008 | Dometic Rooftop RV Air Conditioner
Leaks water
The water may be condensation dripping in an area where the catch components are not able to catch it. The largest line that exits the cold coil and ends at the compressor should be insulated without any tubing showing all the way back to the compressor, deficits in the insulation (even small ones) could cause condensation to form and drip.
Mar 09, 2017 | Goldstar DH5010B Dehumidifier
Chef's Choice 678 Cordless Electric Kettle Logo
88 people viewed this question
Top Chef's Choice Kitchen Appliances - Others Experts
Rommel Balcita
Tom Chichester
Jerry Martin
Are you a Chef's Choice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
