Question about Philips 42PF9630A 42 in. Plasma Television
I have a philips 42pf7220a/37. when i turn it on the picture is fuzzy and red.
  • edgardlamare May 03, 2009
    The picture on my 42PF7220A/37 has red horizontal fuzzy lines.
  • Anonymous May 04, 2009
    My 42 Plasma just became with red dots all along the display and + lines.
  • 3 Answers
Any luck with fixing your Model#42PF9630A/37 as I am having the same problem with mine?
Thanks
Posted on Aug 25, 2010
My kids have lost their remote control for their dynex 22" lcd. How can I replace it? Will a universal remote control work? Will I need a code for dynex?
Posted on Feb 23, 2009
I have a philips 42" plasma t.v.model
hello sir Dave!!!
welcome to fixya..
Lets find out if that problem is worth to repair or not..I need some info regarding your TV such as how many flash of LED lights in front?..It will help to diagnose where the fault came from..
Please reply to this tread to post the info I need..
Thanks for using fixya..
regards,
Chester
Feb 24, 2012 | Philips Magnavox 42MF521D/37 Television
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
I own a Philips 42PF7220A/37 42'' TV (LED flashes red, some people on the net say its the capacitor c2074 to be replaced with a 2200uf 35v. for some reason i cant seem to find that capacitor number. can...
Most likely the problem is your Philips 42PF7220A/37, may not have the same power supply board as other people are talking about on the net. So, the C2074 capacitor maybe under a different number.
The best thing I would do if I had the same problem is to get a Service Manual on the internet. It cost about less than $20. Right now your TV is in " Protection Mode" and blinking a trouble code with the red light. The Service Manual will tell you what the red light blinking code means. Plus, it will give you schematics, part numbers list, and test point for diagnosing. It's better to have a manual for fixing than going by guesses over the internet.
Jul 17, 2009 | Philips Televison & Video
I have a phillips 42pf7220a/37 and 7 blink led
The Ymain Board is out if you have the back of the tv exposed disconnect the ymain board and then plug in the tv set and turn it on. the light should remain green and no longer flash. If this happens the Y main and upper and lower buffer boards should be replaced
Jun 15, 2009 | Philips Televison & Video
Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Aug 04, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Aug 03, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 42" Plasma TV
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Feb 09, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
656 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
