Question about Hoover Nextra HNF 3167 Top Load Washer
Hoover 750lb,8 year old. one year ago this washing machine on occasion stopped aggitating and spinning intermittently on the wash and spin cycle.the 14.uf capacitor was dodgy so i replaced with a 15uf as that was all i could get my hands on.shortly after this the machine washes, aggitates, spins all the time but it aggitates in one diraction only (causing all the clothes to wrap around the fins) also ther is a knock in the motor in the spin cycle,about 3times a second.it seems the motor stops and starts (jerky) causing the noise ? i definatly want to fix this machine. i am also looking at a machine from new could you recomend any or tell if a fishpaykeel gw712 is a good choice. cheers sam.
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
  • 351 Answers
SOURCE: hoover washing machine 550mb keep
Hi are the clothes tangled up around the agitator if so the gearbox may be faulty or the brake may be worn,is it washing in both directions
Posted on Oct 09, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
SOURCE: GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Posted on Mar 05, 2009
philbran
  • 242 Answers
SOURCE: no aggitation or spin, high pitched noise.
Sounds like you have a broken motor coupling , empty the unit , tilt it back against something so you can get a good look under it , the motor is in the middle of the pump[front side] and the gear case[back side] the shaft comes out of both ends of the motor , look for the part that connects the motor and the gear case , it is a small round rubber and plastic piece with prongs , all of the prongs have most likely broke off. , replace this and it should be fine. let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
Have a maytag Neptune washer, it spins and rinses but no aggitation in wash cycle, suggestions? I'm not sure if it's worth fixing since it is 8 yrs old!
Hi
There are various factors that you can check out when a washing machine won't agitate. Please check the bellow link to troubleshoot your problem.
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntagitate
As you are saying the machine is 8 years old then if the problem does not resolve then you need to take your machine to the dealer for a thorough check up.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
Help my hoover w/machine will not agitate or spin.
ok does that mean u know how to bypass lid switch so u can see the agitator and bowl while it is cycle? normally when the lid is lifted the machine stops.sorry to ask u this question but it will help in fixing your unit.please reply 4 more help.
Apr 15, 2010 | Washing Machines
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Hoover 550 MA Top Loading Washing Machine
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Hoover Nextra HNF 3167 Top Load Washer Logo
67 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
