Question about Orion Cobalt 2105 XP Car Audio Amplifier
Where does power steering fluid go for 2006 chevy cobalt
I cant figure out where the power steering fluid container is at?
  • 3 Answers
There isn't one it uses an electric motor not pnematics
Posted on Mar 01, 2011
Hi there, i have a orion cobalt 2105xp 400. i have hooked all up, but very little bass. i have 1 10" boston acoustic sub. i noticed that the led is constant red, is it supposed to be green, crossover...
amp is in protect mode. check your wiring and make sure your sub is wired properly for ohms. dual 4 ohm in parallel = 2ohm. dual 4 in series is 8 ohms. dual 2 ohm parallel= 0.5 ohms and in series 4 ohms. check ground and power wires. make sure sub isnt blown. a blown sub WILL cause this on any amp.
Sep 10, 2011 | Orion Cobalt 2105 XP Car Audio Amplifier
Need to install a cdplayer in 70 chevy truck?
Because of the year of the truck you will not have any wires pre-wired in the truck, go to a Radio Shack, car audio store or Best buy and buy yourself some speaker wire for vehicles, about 5 ft of 14 - 16 gauge yellow wire, 5 ft of 14 - 16 gauge red wire a couple of 10 amp fuses and 5ft of 4 gauge black wire.
You are going to run the Yellow, Red, Black wires together from the radio space where the radio sits in down to your steering column, the speaker wires will go to your speakers from the radio, a + and a - lead to your speakers and connect them as needed.
Now back under your dash you will connect the yellow wire from the radio to the 12 volt + wire under your steering columns 12 volt power wire with a fuse inline, if you hook up a test light to this wire it will light up the test light without the car switch being turned on, the red wire will hook up to your ignition switch wire and your balck wire to the vehicles ground chassis, basically ground that wire to a non painted surface of the vehicle. This radio needs to be hardwired like I explained.
Good luck and hope it helps.
Lex.
May 21, 2010 | Car Audio & Video
Where is the power steering fluid located on the 2007 cobalt?
It is electromechanical not hydraulic so no fluid is needed.
Jan 04, 2010 | Orion Cobalt 2105 XP Car Audio Amplifier
Subwoofer trouble
does your deck have a sub control on it sub on or sub off are your rca jacks plug in to the right one are your rca cables in good shape speaker wires hooked up properlly amp is set on low pass filter
Jul 06, 2009 | Car Audio & Video
How much?
Hello k_davis1004,
The Orion Cobalt 2105 XP is a relatively low-power 2-channel amp. I've seen it on eBay Express for as low as $25. How much it's worth depends not only on the condition but also the intended use. If you are the buyer, and really need a small 2-channel to power a set of normal speakers, I'd say buy it if you can get it for $25-50.
On the other hand, if you're the seller, don't expect a rush of buyers. There's just too many very good little 2-channel amps out there selling new for $100 or so. And with a new purchase, the buyer typically gets a manufacturer warranty, possibly return or exchange, and technical support if needed.
Orion makes good stuff. And their reviews from users is generally very positive.
Hope this helps.
Apr 27, 2009 | Orion Cobalt 2105 XP Car Audio Amplifier
Key stuck in the ignition.
Try putting your car in neutral then back in park. Most of the time the key won't come out if the gear shift doesn't lock in park. Try lifting your steering wheel. Use a pair of pliers and wiggle gently on the back of the key.. Maybe it'll disengage.
Feb 10, 2009 | Orion Cobalt 2105 XP Car Audio Amplifier
Steering trouble
Sounds like a vacuum leak or something to do with the vacuum system.
Feb 11, 2008 | MTX Thunder 1501D Car Audio Amplifier
Need a lil ore help!!!
If the overcurrent of DC offset lights are not green, the amplifier probably has blown output transistors.
To eliminate other problems, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally (all lights green), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 05, 2008 | Sony XM-2150GSX Car Audio Amplifier
Orion Cobalt 2105 XP Car Audio Amplifier Logo
215 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
