Question about Black & Decker Steam Xpress AS250 Iron with Auto Shut-off
I cant figure out how to put the water INTO the iron
I have one with holes on the bottom, and i cant figure out how to get the water in.
  • inuyasha_lov Feb 23, 2009
    Thanks! I really appretiate it! :D
  • Anonymous May 14, 2009
    Dont know how to put water in
  • 76 Answers
Looking at the front of the iron there is a spray nozzle and right above it there is a spot that opens to fill with water.
Posted on Feb 23, 2009
2 Suggested Answers
jaylex
  • 417 Answers
SOURCE: Water shooting out bottom holes
This normally means that the iron is not heating up enough check that you have adjusted the temp so it is not as the water will either come out of the bottom when not hot enough to steam or when the jets get dirty and need cleaning.
Thanks J
Posted on Feb 16, 2008
My steampress 660 is has black stuff coming out
Hi Beverly. The "dried stuff" is scale which occurs naturally in tap water. You should always use DISTILLED water - buy litre bottles (approx.$2.ea Home Brand) all supermarkets. Electricity off, empty out all the water in your iron. Half fill with distilled water, cover the filling hole, and shake water inside iron side to side, up and down, vigorously, empty distilled water out and watch carefully to see if water runs clear or has sediment coming out - may need to repeat this action. When water runs clear re-fill iron as normal with distilled water. Put iron on lowest STEAM setting, LIFT up iron but with soleplate facing down onto an old rag/towel (brown water may come out) press steam button on & off to try & clear the holes. Turn iron off, allow to cool. Thick cloth wipe soleplate over getting into the holes if they have not cleared. Triple wrap a wooden skewer in cloth soaked in white viegar or "scale remover" and circulate it around the blocked holes. Go very carefully do not scratch the coating on the soleplate or holes - very important. Let us all know how this goes please and if I have been of help, do hope so. Good luck, Chris
Feb 12, 2015 | Irons
I cannot get my GCSBDS212 steam iron to make steam.
Have a look at the steam holes in the bottom, they should be nice an clean with no blockage. If they are blocked up you will need to remove the calcium buildup inside the iron. Get some LimeAway at HDepot, pour it into the water reservoir, let sit overnight. Next day turn the iron on and try steaming on some old papers covered with an old rag or towel, once it starts working steam for a few minutes, then unplug, drain it, put in clean distilled water and flush it out until the steam comes out clear. Use distilled water not tap water, it has much less mineral content and will be less likely to plug it up. Most pharmacies and Walmart sell distilled water. ! gallon about $1.25.
Feb 05, 2015 | Sunbeam GCSBDS-212 Digital Steam Master...
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Philips steam iron no steam and red tap light is flashing even when filled up with water it's still getting hot and water is boiling but steam fiction not working as red light will not go out
It sounds like the flow holes are CLOGGED with scale inside. To clean it out:
1. Drain the water/steam out the pour-in shoot at the top of the handle, over the sink. Is any crap coming out?
2. Take some VINEGAR and pour it straight into the fill pour-in shoot. Don\'t dilute it. Fill up the IRON to full line. Let the vinegar SOAK the inside of the COLD iron for 15-20 minutes, by placing it FACE DOWN on an old bath towel, on a heat-resistant surface, such as a granite counter top, or metal cookie sheet. Don\'t put the towel on the ironing board!!! It may get stained badly. Let it sit, COLD for 20 minutes. You can swirell the vinegar around by shaking the iron.
Stand it up on its flat end, with the vinegar inside, still. Take some fresh vinegar and dip Q-tips into the vinegar and clean the slots and holes on the bottom plate. Any burn streaks or soil can be removed with wiping the plate with vinegar. After you clean all the holes and slots with vinegar from the outside, TURN ON THE IRON with the vinegar inside. The vinegar will heat up and should come out the holes. If any holes are not blowing vinegar/steam, clean them with q-tips again. Don\'t let all of the vinegar inside steam out!! Just heat it enough to make sure all of the holes are clean. Some white film may come out of the holes on to the face plate--it is calcium build-up from using tap water in the iron.
Now DUMP out vinegar inside the iron and reservoir through the pour-shoot You may see crud and crap coming out. Repeat the process of filling it up, steaming through the holes etc. until the vinegar comes out clear!!!
DON\'T use tap water in any IRON. Use distilled water, or even bottled drinking water (without flavoring, additives, of course). This will prevent corrosion and calcium build up in the iron.
ALWAYS completely drain the iron from the pour-in spout each time you are finished using it!! After pouring out the tank\'s water, you can set the iron to STEAM HIGH, and force any water inside to boil off and out of iron.! Never keep water in the reservoir or iron.
I set my iron, when hot, and done using it, with the pointed side DOWN in the sink drain to make sure it is dry.
So clean it with vinegar often, use bottled drinking water or better, distilled water and it will prevent this.
Oct 24, 2013 | Irons
LOW WATER LIGHT stays on when water tank is full and no steam is produced.
Check the steam holes at bottom to see if holes is pluged with caculm build up that plug holes. To clean holes us calcum cleaner. Use decression . Use distalled water. Not tap water. There is probably a float inside of tank. Deposit calcum probably has stuck it. This is dependent on the brand and how old it is.
Mar 25, 2010 | Conair Compact Garment Steamer Iron
I simply cant get the iron to stay on. It shuts off
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 23, 2010 | Euro-Pro Shark GI490 Iron
Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Jun 11, 2009 | Rowenta Professional DX8900 Iron
Water leaks out of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Nov 23, 2008 | Black & Decker Steam Xpress AS250 Iron...
LEAKING IRON
This was happening with mine - leaving trails of water behind as well when I ironed. I took it all apart (figured it was already broken, what could I do worse?) I discovered that there is a rubber gasket around the hole that lets water move from the reservoir to the heating plate. The two surfaces (reservoir and plate) are held together by screws, which compresses and seals the gasket. The bottom surface of the reservoir section had been cracked (due to a drop on the cement floor, probably, and the two surfaces could no longer fit tightly together, the crack allowed it to flex, and water leak out. In other word, once it's leaking like that, it's time for a new iron. Sorry I can't offer a fix, but at least a explanation!
Jun 25, 2008 | Rival IR600 Iron
Thanks J
Feb 12, 2008 | Euro-Pro Shark GI490 Iron
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off Logo
364 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
