Question about Dryers
I have a Whirlpool Dryer # LER3624EQ1. I replaced two of the thermal switchs that went out because the fan quit. Now after replacing them the timer wouldnt turn off the dyer. The Dyer works fine but there is no timer.
  • parkhurs Feb 24, 2009
    Where is the resistor at.
    No it will not advance in any position{ time out}. I am thinking of getting a new control but want to make sure. I hooked the two wires on a porcelion [what I thought was a thermal switch] together and after this it would,nt work.
  • 70 Answers
Try changing the resistor. it moves the timer motor
Posted on Feb 24, 2009
  • 1 more comment
  • WRMtech
    WRMtech Feb 24, 2009
    part number is FSP279872. Is it not advancing on the "timed" dry?
    OR is it not shutting off on the "auto" dry? If it isthe auto dry where you are having it run forever, try removing the duct from the dryer and running a heavy load. IF the timer then advances, you willneed to get the duct to the outside cleaned. Keep me updated!
  • WRMtech
  • WRMtech
    This porcelin part, was it just hanging out in the top control area? near the timer? if so, that is the resistor,and you can not just "jump" them out. I think they have orange wires going to it on the whirlpool units.
Whirlpool Dryer LGB6000KQ1 - Dryer Doesn't heat nor does timer advance.
Probably the heating element. They go bad more often than timers.
Jul 25, 2017 | Whirlpool Dryers
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
My dryer isnt getting hot. its a wp model number LER3624EQ1
Check the thermal fuse, the heating element, all thermostats and the thermal cutout. If these are all right could be the centrifical switch on
the motor.Or wiring of course.Hope this helps
Oct 04, 2011 | Whirlpool LER4634J Electric Dryer
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Electric dryer problem
A quarter dropped inside the machine usually will not cause it to stop running.
Most likely, the start switch or door switch has failed. Others failures can cause this symptom: bad timer, bad thermal fuse, bad belt, bad motor, etc.
Apr 09, 2010 | Whirlpool GEQ8831L Electric Dryer
Electric dryer doesn't heat.
Probably a bad heating element. There are a few different styles, you'll just need to lookup your model number on an appliance parts website, find the right part, and then do a quick search on replacement. There are probably ten or fifteen websites that have instructions to replace heating elements.
Here's one where you can buy the part, the element is part number 17.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Dryer-Parts/Whirlpool-Parts-LER3624EQ1/Whirlpool-Parts-81777.cfm
Jan 15, 2010 | Dryers
WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
549 people viewed this question
Top Dryers Experts
