Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Connected motor,it worked. Disconnected then connected again it
Failed. repeated connect it worked, repeat connect again it fails. Sometimes it will run sometimes not!
  • 2 more comments
  • donkey24 Feb 23, 2009
    solution did not address my problem. surfaces are clean and have power but the motor still doesn't work.
    solutions sent me did not work. Why would timer MOTOR work sometimes and not others when conditions are the same?
  • donkey24 Feb 24, 2009
    Solutions
    Solutions you sent me did not work. Motor will work sometimes and not other times with the same conditions. I plug it in and it may run and the next time it won't. I'm talking about an intermatic mechanical time switch T104.
    Brigadier General:
  • 3,614 Answers
Better check and clean the surface. o
Posted on Feb 23, 2009
  • micromaster
    micromaster Feb 23, 2009
    you should check all the wiring connectiions fropm there, a possible loose connections might do so.
  • 547 Answers
Not getting right amount of power.
  • 1 more comment
  • albert getty
    albert getty Feb 23, 2009
    this may be lose wire or bad conicetion
  • albert getty
    what i said was the same as the guy you said fix your problem?
  • albert getty
    albert getty Feb 24, 2009
    power is not high or low enought for motor motor shuts down then resets and works again
Battery was low 1% plugged it in was charging, left came home couple hrs. Later! Now won't turn on, won't do anything??
remove the battery press the power button for more than 10 seconds then release and repeat the process, then insert the battery and connect the charger again wait for sometimes. Hope will help. If fails you have a drained battery try busting the battery.
Nov 23, 2015 | Tablets & eReaders
Garmin 265wt
I suggest you contact these guys...they are really good: www.nabilselectronics.com
Feb 17, 2014 | GPS
Edimax
Put everything on an Uninterruptible Power Supply (aka battery backup)
Aug 04, 2012 | Computers & Internet
Invacare MKIV R11 Flashing lights
One of the most common controllers, codes to help you and others.
VSI & VR2 Joystick error flash codes:
1 RED BAR:
Low Battery Voltage The battery is flat (more likely).
Or the battery has a bad connection (which is unlikely)
2 RED BARS: Left Motor Disconnected The left motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
3 RED BARS: Left Motor Wiring Trip The left motors wiring has a short circuit. Check all connections and leads for wear and chafing between the left motor and the battery cables or chassis
4 BARS: Right Motor Disconnected The right motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
5 BARS: Right Motor Wiring Trip The right motors wiring has a short circuit. Check all connections and leads for wear and chafing between the right motor and the battery cables or chassis
6 BARS: Activated if you turn on your wheelchair with an external device like the Charger still connected.
7 BARS: Possible Joystick Trip, Make sure that the joystick is in the centre position before switching on. If you still get this when switching on then joystick is probably faulty.
8 BARS: A control system trip. Make sure that all connections are secure and if so the power module or control pod is probably faulty. Test by substitution of known good one.
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
10 BARS: Over voltage detected. This can happen with a bad battery connection although unlikely. More likely your battery charger is faulty and is overcharging your batteries quite severely.
1 BAR to 10 BARS and back in a "ripple" every few seconds. Joystick not cantered when turned on. Switch off and try again.
1 BAR to 6 FLASH every few seconds. System Asleep. Switch off and back on. Time before sleep can be adjusted or disabled in programming
Hope this helps, If so please click the "Yes" button
Regards, Mark.
Jul 12, 2012 | Invacare Pronto M51 Power Wheelchair
My acer aod270 does not see the harddrive. How do I fix it?
Be sure to check that all the cables ect. are connected tightly.Because if one is lose that may be why your BIOS doesn't always see the hard drive. BUT If the "clicking noises" you hear are coming from your harddrive it could be that it is failing. You could try reformatting the drive and starting over with your install of Win 7 but if the harddrive is failing which hearing any clicking noises indicates than that harddrive is no longer going to work nomatter what! That's what happend to me several times with harddrives and the only option was to replace it with a new one. This sometimes just happens or because of wear & tear or bumps/drops over time to the harddrive.
May 19, 2012 | Computers & Internet
Power steering failing repeatedly on 2005 Chevy Cobalt
the steering motor is located on the colum under the dash,poor design.I bought one at a salvage yard for 150 bucks.took about 2 hours to replace it.you cant just replace the motor,it all comes together
Jan 31, 2010 | 2005 Chevrolet Cobalt
I keep getting a f50 code it says press stop and start again but it still comes back with the f50 code
Hi
Thanks for using FixYa. F 50 flashes when the motor rotor position sensor (RPS) senses no rotation(Motor Stalled). Does basket turn freely? If not, make sure bottom shipping pack has been removed. Remove the basket and look for foreign object. If basket turns freely, then perform the below mentioned diagnostic test--
Motor Circuit TEST
This test checks the wiring to the motor and rotor position sensor; and the motor and rotor
position sensor themselves. NOTE: Drain water from tub.
1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this step failed.
2. Unplug washer or disconnect power.
3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
4. Remove the console to access the machine/ motor control assembly.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6. If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range shown in the wiring diagram on page 7-1. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to
step 7.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical
connections, reassemble stator and motor cover and repeat step 1.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. If there is continuity, go to step 11.
If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Sep 22, 2009 | Kenmore Washing Machines
Fails to connect during receipt of fax
You may have to decrease the transmission speed and turn off the ECM using the steps given below:
1. From the control panel, press Fax Mode.
2. Press "Menu."
3. Press "Up" or "Down" repeatedly until "Send Setup" appears.
4. Press "Select."
5. Press "Up" or "Down" repeatedly until "Max Speed" appears.
6. Press "Select."
7. Press "Up" or "Down" to select a "9600 bps."
8. Press "Select" to save the setting.
9. Press "Up" or "Down" repeatedly until "Send Setup" appears.
10. Press "Select."
11. Press "Up" or "Down" repeatedly until "Error correction" appears.
12. Press "Select."
13. Press "Up" or "Down" repeatedly until "OFF" appears.
14. Press "Select" to save the setting.
Apr 21, 2009 | Lexmark X7350 All-In-One InkJet Printer
Failure to switch on
fails to switch on again despite repeated attempts.
this is due to power supply failure.
please call skilled tech to fix it.
Oct 14, 2007 | Televison & Video
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
15 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
