Question about ASUS P5W DH Deluxe Motherboard
Continuous beep and windows crashes
I have recently built a computer with the spec below. I have built other computers before and never had a problem.
Asus P5q3 Wifi MB
q9550 Intel quad core @ 3.2ghz
Asus Arctic square CPU cooler
2x OCZ 2GB Ram @ 1333mhz (i think)
1GB Radeon 4870 Graphics card
1000wtt PSU (reputable make - can't remember its name)
Windows vista 64bit OS
Currently installed softwares - Adobe photo suite CS3, Asus MB utilities, Sling media, Mozill Firefox, Veo web player.
I usually build computers for friends and family - never had any problem, this one was for myself. Unfortunately i have not got it to work probably.
My problem is that after windows load up it crashes after few minutes of usuage - this is without opening any programs or games. Sometimes the computer freezes before it has actually loaded up.
I have not added any new hardware, software or drivers. Below are some of the things i have done to find the problem.
1) I have replaced the graphics card with the above spec (Prior to this I had a Radeon 512 and 1gb graphics card) - thinking the Graphics card may be overheating and has its day.
2) I have replaced thge PSU - thinking it might not be giving enough power (prior to the replacement i had the galaxy 100watt psu)
3) I have tried to clear out the CMOS just incase I have overclocked too much by mistake
4) I have also tried to run it in safe mode to disable some of the services - it has crashed then also.
5) I have also reinstalled and reinstalled over again and again with minimum hardware and software.
6) Cannot remember but i think i have actually replaced the MB also from gigabyte.
As you can see guys I have tried many things but I cannot still seem to resolve the problem. From the above spec you can also see that i do not have anything much installed on it.
The following were my further thoughts on what could be the possible issue.
1) CPU over overheating hence the continuous beep
2) Windows vista 64bit bit is simply useless
I can;t think of else, please could some share their knowledge in how to fix this - I have spent a lot of money on this PC and have not been able to break its virginity properly yet.
Many Thanks
  • Ustadf Mar 07, 2009
    Sorry for taking too long.
    I have tested the RAM with Memtest Deluxe, and did a Stress test. Both test have been done outside OS and inside OS.
    Unfortunately sometimes it crashes before it can finish the test. The test suggested that the RAM has a problem.
    Contacted the manufacturer, they suggested to set the RAM in BIOS to Stocks clock. Since then the MB does not seem to recognise the RAM and will not boot up, it gives a continuos beep followed by two beeps and a pause. The manual suggests that the MB is not recognising the RAM.
    I have got an RMA from the Manufacturer (OCZ) it's taken a week. Will let you all know when i receive the replacement and see if the problem perisists.
    Problem Solver:
  • 18 Answers
Check the memory, My machine is currently doing this.
Posted on Feb 24, 2009
Computer beeps but won't boot
if the beep is continuous it is likely the ram modules have dislodged.
however if it is just the normal short beep you get every time the computer starts normally, then it is just the post beep this simply indicates that the hardware has passed the Power On Self Test or POST for short. this would suggest the issue is windows related more so then hardware related, i would try using a windows 7 recovery or pe disk to boot it from.
Mar 02, 2017 | Computers & Internet
Continuous beep at startup when loading windows files
If you mean that your computer always beeps at startup, this is a sign that everything is working as it should. This is a good thing. However, if you mean that your computer beeps continuously without stopping, and your computer does not load windows properly, you may need to use a windows disc to reinstall your operating system. If your computer still does not work, you may need to take your motherboard to your nearest pc store to have it looked at. Preferably go where you bought it.
Feb 18, 2013 | Toshiba Satellite Computers & Internet
APC UPS BR 1300 continuous beep warning means what?
You have a "Open" battery. The voltage may be good but once a load is placed the computer shuts off. Replace battery
Apr 06, 2012 | APC Power Saving BackUPS Pro 1500
When I press the power button of my CPU i hear 3 Continuous beeps which repeats thrice. Again the beeps come during the windows login. This beep was not there in the begining. It started recently. But...
It is true that your computer is working properly without any trouble.Three continuous beeps means that your keyboard component is not ready to input the data.That's why it is calling you as beeps.You might have to check your keyboard that it is attached with the CPU properly or not.
Apr 06, 2010 | ASUS M4A79 Deluxe Motherboard
Asus Motherboard Constant High POST beep
long beep - memory bank is not plugged well, or broken
continuous beep - no power, loose card, or short.
Aug 01, 2008 | ASUS P4S800-MX Motherboard
DVD-ROM crashes
sounds like your DVD drive is not configurable wit your hamshack system but is with the other computers,i suppose youve checked the manufacturers site for compatability,id do this first you dont want to mess up your hobby system irrepairably
May 28, 2008 | Hi-Val DVD Kit (DVD6X-00R1) Internal DVD...
MSI P6NGM Issues
I would put the old ram back in, and then reset the bios by following the instructions in the motherboard manual. (usually with putting a jumper on some pins)
Harris
Apr 25, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
No video on boot up!!
have you tried to uninstall the vedio driver and reinstall it then let me know.go to my computer icon right click it > go to properties >hardware tab > device manager and check if there is any yellow mark showing.kindly do this in starting your computer in safe mode.
Oct 09, 2007 | Gateway 500XL PC Desktop
ASUS P5W DH Deluxe Motherboard Logo
462 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
