Question about Canon PIXMA MP150 All-In-One InkJet Printer
Print Test page Canon Pixma MP140 - Canon PIXMA MP150 All-In-One InkJet Printer
5 Suggested Answers
SOURCE: canon pixima mp140 error code E4
Push Reset button for 5 seconds
Posted on May 17, 2008
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Posted on Mar 02, 2008
  • 412 Answers
SOURCE: Canon PIXMA MP140 Service error 5100
ok... you have to reset the printer --
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Hpoe this helps
Posted on Mar 09, 2009
pineworks
  • 4041 Answers
SOURCE: Canon Pixma MP140 freezes, only alarm lamp is on, no code error
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Posted on Feb 16, 2010
    pineworks
    • 4041 Answers
    SOURCE: Canon pixma mp140 not printing correctly
    Hi There
    Summary
    Usage of compatible ink and leave the printer idle too long may cause printhead clogging
    What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
    1. Right click in the printer driver name
    2. Select Properties menu
    3. Click Maintenance tab
    4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
    5. If this does not work, perform Deep Cleaning
    And if that not work
    Some times it needs a good clean up but this is up to you if you want to do this,
    But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
    Ok.
    There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
    Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
    It worth a try it worked for me more than ones.
    Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
    All The Best: Pineworks
    Posted on Mar 11, 2010
    To find a driver to install Printer Canon Pixma MP140
    Go to this page:
    Canon MP140 Downloads
    Select your operating system from the drop down menu and you will get a list of available drivers and other software.
    Thanks for using Fixya.
    Dec 20, 2010 | Canon Office Equipment & Supplies
    Tip
    Canon pixma mp140 Drivers for Windows and MAC OS
    Here I will show you where to find drivers and manuals for the Canon Pixma Mp140 photo all in one printer.
    Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
    On the Mac side drivers are available for Mac OS X 10.2/10.3/10.4/10.5
    A full on screen manual, quick start guide and other instructions are also available.
    To download these drivers and or documentation for your printer please visit THIS PAGE
    1. Click on Drivers & downloads
    2. Select your OS ( Operating system, windows, mac etc )
    3. All available drivers, documents etc will be available below.
    For some of the documents a PDF reader may be required to open and read / print them.
    To obtain a PDF reader, read this page PDF Documents. Pdf reader(s)
    Thank you for reading and I hope your printer is up and running again.
    -Ekse
    on Mar 11, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    CANON ERROR E27
    Canon MP140 Error Code injet printer reset procedure:
    Canon waste ink tank problem.
    1. Change the waste ink absorber
    2. Reset waste ink tank counter
    Go to the service menu;
    1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
    NEXT
    2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
    NEXT
    3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
    NEXT
    4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
    NEXT
    Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
    NEXT
    Hit 4 times for waste ink counter reset.
    The number of the Reset button pressing LED
    0 time ... Green Power off
    1 time ... Orange Service pattern print
    2 times ... Green EEPROM print
    3 times ... Orange EEPROM reset (EEPROM reset)
    4 times ... Green Waste ink counter reset
    On the end press POWER button to exit .
    FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
    Jul 31, 2010 | Acer Office Equipment & Supplies
    Will not scan due to no colour ink. do not want to
    hi,
    As you dont want to use the colour ink,When you give the print command you wil get the print properties page ,In that you can select black and white so that you wil not use up the colour catridge. It uses black catridge only.
    thanx
    Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
    I require price of this model CANON MP140 PHOTO AIO P/C/S4800X1200DPI PMFP7 AllInOne InkJet Printer
    Hello: Here is some information you might be lookin for.
    PIXMA MP140 PIXMA MP140 Photo All-In-One Printer Item Code 2174B002 Suggested Retail Price $79.99† Overview Compact and Stylish All-In-One Photo Printer. Based on accelerated testing by Canon in dark storage under controlled temperature, humidity and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints results may vary depending on printed image, drying time, display/storage conditions and environmental factors. Photo print speeds are based on the standard mode driver setting using one or more photo test patterns and select Canon Photo Paper.
    Dec 24, 2009 | Office Equipment & Supplies
    No print in Vista
    this printer is NOT compatible with vista
    Feb 26, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
    Canon PIXMA MP150 All-In-One InkJet Printer Logo
    1,470 people viewed this question
    old marine
    old marine
    Corne Viljoen
