Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv clicks then turns off red blinking light blikns 7 times
The picture wont show up
  • Anonymous Mar 07, 2009
    When I turn on my Sony 36" WEGA I hear the audible click and the sound comes on, however, the picture does not appear. The red standby light on the front of the unit blinks 7 times and pauses and then continues to repeat the 7 time and pause.
  • Sony Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Apr 02, 2016 | Panasonic Viera TC-P65S1 65 in. HDTV...
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Wont turn on clicks then clicks back off red light blink 7 times
check the capacitors and replace the power components check mother board also .. not handy with electronics and soldering call tv repairman 75-150 dollars Fix ?????
Sep 21, 2012 | Panasonic TC-50PX24 50 in. Plasma TV
Red LED Light Blinks 7 Times Tv Wont Turn On PLEASE HELP!
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You must have through knowledge in electronics to proceed. This is a very skilled wor. You must have all measuring instruments, and ability to follow its schematic diagram.
Jun 12, 2012 | Sony KV-36XBR400 36" TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Black screen, blinking green light, nothing happens
Hi it is the indication of error code......can you tell me how much time does light blinks......
Jun 03, 2009 | Mitsubishi WD-52528 52" Television
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
Mitsubishi 53 projection TV- won't turn on- Red lamp light is on. Tried to turn the tv on and the lamp light turned amber and we heard the sound of the tv and then it shut off and the red light "lamp"...
unplug the set for over an hour, if the same thing happenes you will need service. Look at the power light, it should be blikning. If you count the # of blinks between pauses it will tell you the problem
Jan 10, 2009 | Mitsubishi WS-65513 65" Rear Projection...
TH-42PX80U
i have the same problem but i have 11 blinks
Aug 13, 2008 | Panasonic TH-42PX60U Television
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
176 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
