Question about Brother SX-4000 Typewriter
1-to go automatic change page 2-when typing need to change the next line
How do I change view mode?
Posted on Mar 04, 2009
What could cause norstar m7208 phone to not receive incoming calls
If you have lines appearing on your phone and they don't ring you need to program lines to ring. This type of programming is done from a M7310 phone. Page 323 of this manual shows how to program this on a NorthStar MICS Ver 6 phone system.
Enter the programming mode : Feature **266344
You will have 4 programming buttons on your phone, normally the 2 top left and 2 top right of the 2 vertical rows.
top left = move up one level
lower left = back
top right = select
lower right = next
once you enter the programming mode press next to "Terminals and Sets"
press select
enter your extension number
press select
press next to "Line Access"
press select
press next to "Line Assignment"
press select
use the next key to go to the line you want and use the soft-key below the display to change it from "Appear" to "Appear and Ring"
May 05, 2015 | Nortel Norstar M7208 Telephone
Windows xp stops loading and goes to disk scan. Disk scan does not find any error on the drive and restarts booting xp, which stops at the same point and goes to scan again...
First you need to disable the page file:
  1. Open Control Panel -> System and Maintenance -> System.
  2. In the left "Tasks", click on Advanced System Settings.
  3. You should come to "Advanced" tab. In "Performance" section, click on Settings button.
  4. Click on Advanced tab.
  5. In the "Virtual Memory" section, click on Change button.
  6. By default, "Automatically manage paging file size for all drives" setting is selected so that Windows can manage the paging file without user's interruption. Uncheck the check box of Automatically manage paging file size for all drives.
  7. Select and highlight the appropriate drive that users want to change the paging file settings under the box of "Drive [Volume Label]".Select "No Page File"
  8. Restart the system
Next do the following:
  1. Click on your start menu and open the run dialog.
  2. Type "cmd" and return (note: dont enter quotes)
  3. Next type "fsutil dirty query e:"
  4. If the return message indicates that the volume is dirty go to step 5
  5. Next type "chkdsk e: /f /x"
  6. After that finshes repeat step 3.
  7. If it is no longer dirty then reboot and you should notice no more ckdisk.
Jun 01, 2011 | Microsoft Windows XP Home Edition English...
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
Hello , i have a Acer aspire one and i have wireless problems. I cannot connect to a network ... and even on cable it does not work. My wireless finds the network but just won't connect. if i try to...
Your 'autoconfiguration' settings have been changed.
Do this......go to the start menu and type 'services' in the search bar and press enter.....when the window pops up showing the services, make sure that the left column is focused on 'services'
now, scroll all the way down on the middle column and find the services labeled; 'WLAN Autoconfig' and 'Wired AutoConfig'
These should be set to automatic.
to do this, simply double click the service, and select 'automatic' in the 'startup type' drop menu.
you may have to click start on the left upper portion of that window, but next time you start your system it should automatically search and connect with a valid ip
Nov 16, 2010 | Acer Aspire One AOA150-1126 Notebook
Cingular WAP settings
Hi..i am providing you with the WAP and other settings,but still if you need any help,then please contact Cingular at 866.CINGULAR(866-246-4852)
For CSD (Wireless Internet)
Function Setting
Settings Name: Cingular Wireless Internet
Home Page: http://device:home or http://device.home
Session Mode: Permanent
Connection Security: On
Dial-up Number: 14152441012
Gateway IP Address:
Authentication Type: Secure
Dial Type: ISDN (on network)
Analogue (off network)
Login Type: Automatic
(All upper case)
Password: CINGULAR1
(All upper case)
For GPRS (Wireless Internet Express)
Function Setting
Settings Name: Cingular Wireless Internet Express
APN: wap.cingular (lower case)
PDP_Type: IP
Gateway IP Address:
(All upper case)
Password: CINGULAR1
(All upper case)
Now to set up MMS (Multimedia Services)
Gateway IP 1:
Port 1: 9201
Domain 1: (blank)
Service type 1: WAP
Gateway IP 2: (leave alone)
Port 2: 9201
Domain 2: (blank)
Service type 2: WAP
DNS 1: (leave alone)
DNS 2: (leave alone)
Timeout: 10 minutes
CSD No.1 14152441012
password: CINGULAR1
Speed(bps): 9600
Line type 1: ISDN
CSD No.2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed(bps)2: 9600
Line type 2: ISDN
GPRS APN: wap@cingular
Password: CINGULAR1
Good luck :-)
Apr 22, 2010 | Computers & Internet
You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop. How though?
Changing programming on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) - display should read "lines"
4.- Press "SHOW" (top right arrow)- display should ask for a line number
5.- enter in the line number you wish to change the supervision on in a 3 digit format. ex. line 1 = 001
6.- press the show key (top right arrow)
7.- The display should say Trunk/line data
8.- Press "show"(top right arrow) - display should read "trunk type"
9.- Press the next key (bottom right arrow) 7 times"
10.- the display should say "trunk mode: unspr"
11.- Press softkey "CHANGE" to "super"
repeat steps 5 - 11 for the remainder of the lines Press the Rls key when finished
Nov 03, 2009 | NorStar M7324 Telephone
I need to change the IP address on my hp color laser jet 2840 coud you help me with that
Most HP printers can be reset to factory defaults (or cold-reset ) by turning the printer off and holding down the Online or Go button while turning the printer back on. The printer control panel display should read "Cold Reset" or "Restoring Factory Settings" or something like these lines. This will remove any IP address that the printer had previously.
When you plug it in, your router should have assigned an ip address automatically. Go into your router and look at the attached devices and it will show you what ip address has been assigned to each device on your network.
Use Web Interface or Manually Assign an IP address NOTE: Network HP Printers allow you to manage them via Internet Explorer. You can enter the IP address that the printer currently has and access its configuration settings. This assumes that the web interface hasn't been locked.
NOTE: We recommend that you install the latest version of Sun's Java software before trying these steps. See this How To: How to Update Sun's Java 2 Runtime Environment Plug-in.
  1. Print the Configuration page if needed. You will be entering the "current" IP Address.
  2. Open Internet Explorer. Delete EVERYTHING from the Address line.
  3. Enter the IP Address in the Address line and press Enter.
  4. You should then connect to the printer. If this fail, go to the next section to assign the IP address manually.
    NOTE: There are 2 basics versions of the web interface. Type 1 is on newer printers. Type 2 is on older models
  5. Type 1: Click the Networking tab.
    Type 2: Click the Administration button. Click the Configuration tab.
  6. Edit the IP address, Subnet Mask, and Gateway as needed.
  7. Do not change any other fields.
  8. Scroll to the bottom and click Apply. Click OK.
  9. Close Internet Explorer.
  10. Restart the Printer. Print the Configuration page to see if number was set.
NOTE: If the above steps do not allow you to assign the IP address via the Wizard, you will need to do it through at the printer itself.
  1. Go to this HP Support Page.
    Configuring TCP/IP through the Front Control Panel
  2. Click the link to your printer model. Highlight these steps.
  3. From the File menu choose Print. In the Page Range section, click Selection. Click Print.
    Note: For the complete printer user guide, go to the HP Printers Support & Troubleshooting page. Locate your specific printer type and model. On its home page, under self-help resources, click the manuals link. Download the printer's User Guide (not the Getting Started Guide). Look for steps to manually configure TCP/IP parameters from the printer control panel.
  4. Follow the steps from the printout to assign the desired IP Address to the printer.
    IP address will be entered at the IP BYTE prompt
    Subnet mask is entered at SM BYTE prompt
    Gateway address is entered at GW BYTE prompt
    Note: The syslog server IP address (LG BYTE 1=) and timeout (TIMEOUT=) do not need configured.
  5. Once the IP Address is entered, restart the Printer. Print the Configuration page to see if number was set.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | HP LaserJet 2840 Printer
How too change time
Norstar Merdian Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS Time
  • Press "FEAT".
  • Press "*".
  • Press "*".
  • Press "266344" (CONFIG) or "23646" (ADMIN).
  • Enter password "23456" (ADMIN) or "72787" (SCPLUS).
  • You will see "Terminals & Sets".
  • Press "Next" five times.
  • Press "Show"
  • When you see "Hour", press "Change" or "Next" to skip.
  • Type in the hour using military time as a 2 digit number.
  • Press "Next".
  • When you see "Minutes", press "Change" or "Next" to skip.
  • Type in the minutes using a 2 digit number.
  • Press "Next".
  • When you see "Year", press "Change" or "Next" to skip.
  • Type the year in 2-digit format.
  • Press "Next".
  • When you see "Month", press "Change" or "Next" to skip.
  • Type the month in 2-digit format.
  • Press "Next".
  • When you see "Day", press "Change" or "Next" to skip.
  • Type the day in 7-digit format.
  • Press "Next".
  • When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
  1. To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
  2. Enter password (default = 266344) - display should read "Terminals & Sets"
  3. Press "NEXT" 5 times - display should read "Time and Date"
  4. Press "SHOW" - display should read "Hour:___"
  5. Press softkey "CHANGE"
  6. Enter hour - display should read "AM OK or Change"
  7. Select AM or PM
  8. Press "NEXT" - display should read "Minutes:___"
  9. Press softkey "CHANGE"
  10. Enter minutes
  11. Press "NEXT" - display should read "Year:___"
  12. Press softkey "CHANGE"
  13. Enter year
  14. Press "NEXT" - display should read "Month:___"
  15. Press softkey "CHANGE"
  16. Enter month
  17. Press "NEXT" - display should read "Day:___"
  18. Press softkey "CHANGE"
  19. Enter day
  20. Press "NEXT"
Sep 15, 2008 | NorStar T7316E Corded Phone
Nokia 6300
If this is a nokia handset, then please long press #. it will ask u change the line from 2 to 1. say yes. otherwise find the menu for line change. then go there and manully change the line
Aug 31, 2007 | Nokia 6300 Cellular Phone
Brother SX-4000 Typewriter Logo
18 people viewed this question
James Cagle
James Cagle
Jim Keysor
