Question about Dell Latitude 100L Notebook
Is ther away to add another admin account whist a normal user
I have forgotten my admin password and can only sign is as a read only user, is there a way i can set up another admin account as a norml user so that i can access my latop properly and donload prgrammes which i caan do at the moment??? please help
  • 3 more comments
  • pinkkelly26 Feb 23, 2009
    to reinstall wiws meand i have to change the boot sequence and i cant access them due to password, neither does f12 option work
  • pinkkelly26 Feb 24, 2009
    yes i need to remove bios password, any ideas
  • pinkkelly26 Feb 25, 2009
    how do i create a new user with admin rights with out signing in as admin in the first place......
  • pinkkelly26 Mar 10, 2009
    i know how to change the boot sequence but i have tried everything and been in successfull with all attemps. I took my hard drive out and the problem was still there...
  • Dell Master
  • 32,281 Answers
You can only create a new user login with administrator rights.
There is a Linux password recover program around which can reset or remove passwords on user accounts. You need to Google to find it.
The only other alternative is to re-install Windows.
Posted on Feb 23, 2009
  • 2 more comments
  • Chris Hingee
    Chris Hingee Feb 24, 2009
    From your initial details, it appears that you need to remove/reset the Windows Administrator password.
    You should be able to get into the BIOS to change the boot order.
    From your latest comment, is the BIOS password the one you wish to remove/reset, not the Windows password?
  • Chris Hingee
    BIOS or Boot password for http://www.dell.com/">Dell Latitude
    Note: This is for http://www.dell.com/" target="_blank" rel="nofollow" >Dell CP and CPI Latitudes, it has not been tried on other models. Another way to crack it is to create a short in the 24c02 chip (the markings on the top of the chip) between pins 3 and 6 when you power on!
    Before you try that though, remove the hard-drive and see if you get the same error.
    If NOT, then it is a Hard-drive password and not a system password. This fix is for a system BIOS password only. A new Hard-drive should fix it if it boots w/o the hard-drive or is cleared of a system BIOS password.
    The chip is below the processor so you have to solder two very small wires and bring them outside the laptop then reinstall the processor. Short the two wires and power on! Pin 1 is the one with the dot in the corner. Next pin on the same side is 2 then 3,4, and 5,6,7,8 going around the corner with pin 8 being across from pin1. The power on password will be disabled and you will be able to access the system settings via the F2 during bootup as if it was never there. This works for me, works great.
    Only catch is…if there is also a hard-drive password, it will not disable that one and you will get the same message. But at least you will be able to put in a new hard-drive and use the laptop. I haven’t figured out a fix for the hard-drive one yet, except I may try to adapt a cable to connect the laptop drive to a desktop pc and then I should be able to Fdisk it etc. (the laptop looks for the password protection, I doubt the desktop will especially another brand.) You could try to install the hard-drive in another brand laptop. Perhaps then you can Fdisk it etc. to reclaim it.
    For those of you who are not accustomed to soldering PC boards. Make sure the wire does not touch other pins or the case. Do NOT OVERHEAT the chip! Work in short sets of applying heat and let it rest a few minutes between attempts if you can not get it to attach right away. No more than 8 seconds at a time at low temp setting.
    I used some old “wire-wrap” wire. It is very-very small, single solid strand, and insulated. Be sure to ground the solder iron to the case just before you solder and REMOVE THE BATTERY FIRST!
  • Chris Hingee
    Chris Hingee Feb 26, 2009
    You have not explained clearly which password you need to remove or changed, as I previously commented on the 24th. You then replied it was the BIOS password you need to change/remove and then I detailed how to remove the BIOS password.
    Now you are asking about the Windows admin password again.
    Have you removed the BIOS password yet?
    If so you can get into the BIOS setup to change the boot up sequence to make the CD as the first boot device, press F2 to get into the BIOS.
    Then you can boot up with the Windows CD to re-install Windows and create new User accounts with administrator rights.
  • Chris Hingee
    Chris Hingee Mar 10, 2009
    Please detail the exact error messages you get on the copmuter screen.
    Were you able to change the boot sequence to boot up with the CD?
    Did the Windows installation CD boot up and start to install Windows on the hard disk?
Tip
How to Reset Windows Vista Administrator Password With Three Simple Methods?
Have you ever experienced Windows Vista administrator password forgot? Absolutely, there is nothing worse than forgot your Windows admin password when you have a great deal of work to do on your PC. Even though you can enter your computer with a standard user account, you still could not download anything and install programs on your PC. Therefore, how to reset or recover Windows Vista administrator password efficiently?
Here we will show the top three easy and efficient Windows Vista admin password recovery methods to anyone who have Windows Vista admin password forgotten issues.
Method 1: Reset Windows Vista administrator password on safe mode
Preparation Time: about 10 minutes
Pros: Simple and do not need third party tools
Cons: Need an available admin account on your Vista PC
You can reset Vista administrator password on command prompt with an available admin account to enter safe mode first. If you have another Windows Vista admin account, try these steps below:
Step 1: Press F8 when your Windows Vista PC is booting. You will come to the Advanced Boot Options. Then choose Safe Mode with Command Prompt and press Enter.
Step 2: Enter safe mode with an available admin account.
Step 3: Type "net user" and press Enter. The command prompt will show you all accounts on the Windows Vista PC.
Step 4: Type "net user Paul 123" (Paul is the locked admin account's name and 123 is the new password) and press Enter. Now you have successfully created a new password on the locked admin account.
Step 5: Type "shutdown -r -t 00" and press Enter.
Your Windows Vista PC should be rebooted automatically and then you can logon Windows Vista with the new password.
Method 2: Recover Windows Vista administrator password with freeware
Preparation Time: More than 30 minutes
Pros: Free and do not need to change the forgotten password
Cons: The freeware should not work if the password is too long
Ophcrack is freeware for Windows password recovery. This software can help you to recover your forgotten Windows Vista admin password. So that you can regain access your admin account without changing the password.
Ophcrack is used to create a Windows password recovery disk. You need to boot your computer from the disk to recover your password. You can follow these easy steps:
Step 1: Download Ophcrack
Step 2: Burn a Windows password recovery disk with the freeware
Step 3: Recover the forgotten Windows Vista admin password with the disk
You can logon Windows Vista with the old password now.
Method 3: Reset Windows Vista administrator password with shareware
Preparation Time: less than 10 minutes
Pros: Fast and 100% reset the forgotten password
Cons: Not free
Windows Password Recovery Tool 3.0 is easy-to-use shareware to reset forgotten Windows password, including administrator password and other standard users' passwords.
Unlike Ophcrack, Windows Password Recovery Tool is designed to reset the forgotten password. No matter how long and how complicated the password is, this software can 100% reset the forgotten password in few minutes. All you need to do is just three steps:
Step 1: Download Windows Password Recovery Tool
Step 2: Burn a Windows password reset disk with the shareware
Step 3: Reset the forgotten Windows Vista admin password with the disk.
These three Windows Vista administrator password recovery solutions are helpful for us to resolve the Vista admin password lost problem. Now, you are no more Vista admin password forgot matters.
This article is free for republishing
on Jul 12, 2010 | Computers & Internet
Tip
How to Reset Windows Vista Administrator Password with Three Simple Methods?
Cons: Not free
Windows Login Recovery is easy-to-use shareware to reset forgotten Windows password, including administrator password and other standard users' passwords.
Unlike Ophcrack, Windows Login Recovery is designed to reset the forgotten password. No matter how long and how complicated the password is, this software can 100% reset the forgotten password in few minutes. All you need to do is just three steps:
Step 1: Download Windows Login Recovery
on Jun 24, 2010 | Computers & Internet
Forgot my acer laptop password
During the boot up process you will see on the screen press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
Nov 02, 2010 | HQRP AC Power Adapter Battery Charger +...
How to break the administrator password
go to recovery partion and open command prompt by pressing alt "+" D
get into C:\
type " ren c:\windows\system32\utilman.exe oldutilman.exe "
and press enter
then type " ren c:\windows\system32\cmd.exe utilman.exe "
and press enter
RESTART THE PC
GO TO "EASE OF ACCESS" ON THE BOTTOM OF THE LOG ON SCREEN
IT WILL OPEN COMMAND PROMPT AGAIN
NOW TYPE
net user administrator /active:yes
IF SUPER ADMIN DOES'NT GET CREATED
TYPE
net user /add user mypassword
net localgroup administrators user /add
RESTART THE PC
log on using the new admin account ie. "user" ( password will be mypassword)
and change the password of the previous admin account
DONE
***** Most of the time it works .. but sometimes it might not work as well ... So "All the Best "
Mar 14, 2010 | Microsoft Windows Vista Home Premium with...
How do i unlock my acer laptop
http://www.howtogeek.com/howto/windows-vista/change-your-forgotten-windows-password-with-the-linux-system-rescue-cd/
Oct 31, 2009 | Acer Aspire 3000 Notebook
ACER 5630-6288 Win Vista Home Premium Admin Password forgotten
yes there is
login with ur normal user profile
go to run>>type cmd
in the black box...
type net user administrator
it will give u options to change the pwd for administrtaor
May 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Forgot my password. need new password
There are many Windows password reset tools, but I haven't personally tested them. Windows Password Rescuer 3.0 is a widely spread edition on internet...
It supports running with CD/DVD/USB, remove the lost or forgotten password and then log in to your computer without any password.As long as you have another PC to install it and burn it to CD/DVD or USB Drive.You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows when you can not find target user. With this New user account you can and logon your locked computer directly to copy important data from the locked computer if you want to reinstall your Windows system at last.
Jun 13, 2008 | Computers & Internet
Dell Latitude 100L Notebook Logo
98 people viewed this question
Alun Cox
