Question about Hitachi 43UWX10B 43" Rear Projection Television
A red deformation line on the left top screen. The rest of the screen is ok.
  • peniotna Feb 25, 2009
    Can you be clearer? I was thinking of changing the STKs on the convergence board.
    Is there a manuel way to do the alignment?
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiA red deformation line on the left top screen. The - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
  • 121 Answers
Looking into the "convergence" menu may be what is needed. Hopefully it is simply an alignment problem brought about by time and handling.
Posted on Feb 25, 2009
  • Jim Bay Feb 25, 2009
    The simple manual way to adjust is under #4 convergence in the menu. If you can't fix this issue with this procedure perhaps replacing the chips would be a good idea.
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Multipoint blue convergence cannot be adjusted
Sound like you need to replace the STK's and any blown pico's on convergence board.
Jan 20, 2008 | Philips 60PP9202 60" Rear Projection...
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
Fotomorph
try to make your screen resolution higher
Nov 18, 2017 | Digital Photo Software FotoMorph
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Top left corner of screen is black about 3
Do you have a PIP (picture in picture) button on your remote? Could that be it?
Mar 04, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Part of the picture is out of focus
Typical convergence problem. Its 2 ICs that start with stk standing up on the printed circuit board, and this is not a repair for the layman. No insult intendedb there is a lot of High Voltage inside these sets neven when they are unplugged. You also need to unsolder ansd resolder the IC's when they are replaced.
Sep 05, 2006 | Sony KP-48V80 48" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
