Question about Hotpoint WMA40 Front Load Washer
Blocked filter How d I change the filter on a hotpoint aqarious wma40 washing machine ?
    Scholar:
  • 106 Answers
This is for the WD420, but could be useful for you.
The filter is inside the machine. If you machine is still under guarantee I would try and get it done that way. Otherwise turn off the power and pull out the machine to get a the back.
Remove the panel at the bottom where the discharge hose comes out. You should see a black concertina type tube coming from the drum attached by a jubillee clip. The filter is inside. Losen the clip and pull away the tube take out the filter and clean it. When you replace it don't forget to put the ball float back in and check its well fixed by running a spin cycle before sealing up.
(courtesy pollydolly10)
Posted on Feb 27, 2009
How do I change the door seal on my Hotpoint WMA40 washing machine
Best to watch this video on youtube which explains it in detail
May 14, 2014 | Hotpoint WMA40 Front Load Washer
Our Hotpoint Aquarious Extra WMA40 will not discharge water and when it goes through it's cycle the water builds up and the only way it comes out is through the front and soap tray
I would guess something is blocking the drain pump. Collar stays are enemies with drain pumps, couldn't tell you how often I run into that.
Apr 14, 2013 | Hotpoint WMA40 Front Load Washer
Can sumet be blocked in my washer as wen it spins the water dont empty and i get a flood out the door and powder part
You need to clean the filter.
Remove lower rear panel of washer, locate and remove large black hose on bottom of drum.
Remove and clean plastic filter inside the hose.
Jan 22, 2011 | Hotpoint WMA40 Front Load Washer
Stopped half way through cycle and won't drain! any ideas?
Probablyu a blocked filter or pump.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remoive and clean filter inside hose
Check pump for blockage as well, and the drain outlet hose..
May 21, 2010 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA40 washing machine is leaking from detergent drawer- any suggestions ? Thanks
Hotpoint WMA40 washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 27, 2009 | Hotpoint WMA40 Front Load Washer
Brocken door spring
If you have not rectified your problem, you need to seperate the 2 door halves by removing all screws securing the 2 halves, and prize`appart, then you can easily change the spring.
Please rate my solution.
Thanks.
Oct 05, 2009 | Hotpoint WMA40 Front Load Washer
How do I change the door seal on my Hotpoint WMA40 washing machine?
It's a push fit seal. Carefully remove the old one and for help, smear the new seal where it fits the machine and just push it into place securely.
Sep 07, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint aquarius extra wma40 wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Apr 03, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
360 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
