Question about AEG T58840 Dryer Electric
Help ! i have a electra condenser dryer and it was working fine, then all of a sudden i heard this terrible siren noise, and went to see and seen the green empty water light was on, so i emptyed the water, and the light is still on and the siren noise too , plus theres no heat !!!!!
  • baugh_v Feb 23, 2009
    just tried that still same problems !!! no heat , very loud siren noise, and green water light still on !!?? iv emptyed it
  • 547 Answers
Try unpluging it and wait 5 mins then plug it back in
Posted on Feb 23, 2009
  • albert getty
    albert getty Feb 23, 2009
    element needs to be changed
Makes a loud noise
needs new bearing kit ,it will collapse soon,
Apr 09, 2014 | Bosch Nexxt 500 Dryer
Diagram police siren
Hi Anonymous, I'm sure if you went to your local dealer they would be happy to print one out for a small fee. Good luck
Apr 06, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
I have a Kenmore Elite Dryer Model 110.66992500 that will not start. When the start button is pushed, it only makes a click. During the last use, the dryer was working fine then all of a sudden while...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 01, 2011 | Kenmore Elite HE4 Electric Dryer
My dryer works great but makes terrible noises when it runs. Not sure if it's just the belt or also the bearings.
Probably not the belt its usually either your rear bearing or your glides on the front housing (most of the time its a combination of both). Ive never seen a belt cause any noise on a GE dryer. If you dont catch the problem early it could wear down into your front housing. Hope this helps _MJ_
Aug 17, 2010 | GE Dryers
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Noise like a siren when speed increases
hey plinio7,
Having been a jag tech for the last two years, this noise could be a million different things.
But If your sure that its not the wheel bearings then this is where i would start.
I had a few cases where the front diff. was making the noise, the best way to fine out if that is the problem is try to get all four tires off the ground. Start it and put it in drive, and put a longer screw drive or pry bar from the case to your ear. If its very lound then that is your problem.
Let me know what you fine thanks
May 21, 2009 | 2003 Jaguar X-Type
Change belt on electra 37527
Hi what you need to do is take front off the dryer take out old belt the new belt is then placed around the drum around the drive wheel and then under tention pully . thank you for useing fixya
RATE ME
Apr 15, 2009 | Dryers
I can't hear my Galls street Thunder siren model xs100.
bad output transistors or integrated circuit
Dec 29, 2008 | Radio Communications
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
AEG T58840 Dryer Electric Logo
254 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
