SOURCE: sewing machine
I have one but it is in my head what is it doing or not doing I will try to help amy
SOURCE: I have a Brother PE 770 and I can not get the
Just ask the experts if you do not want to bother. but if want to improve yourself, then do it carefully and patiently. would be fine.
SOURCE: How to oil brother PE 770
Brother says it should not be oiled but having 14 of those, I know that it has to be done but a Brother technician will not do that. OILING the machine may cause F05 speed sensor error. See how to solve it under this label.
U need to remove the complete front plastic panel. 3 screws on the top (2 lower the handles, 1 at upper right. Remove 1 screw at the center bottom of the rear panel. Remove both left top/ bottom panels (1 screw each) then the horizontal bottom left panle (2 screws). All the balance is fixed with clips.
First undo the 2 clips under the machine than carefully unclip everywhere. Front panel have 2 wire assembly attached to main board. Regular one is easy to remove. To remove the flat one, send down the upper part of the attchment on the main board.
Don't use reg. thin white sewing machine oil, it evaporate. Use SAE 80 (differentail type) oil or something like taht. Lubrificate all 4 lower shaft supports, rotary hook gears and central pin (from the top, under the bobbin case). Then lubrificate all the upper shaf support and especially all the needle bar mechanism. U need a good light to see upper needle bar support. Lower needle bar support support is the most critical point.
SOURCE: what kind of plug/cord do i use to plug my Brother PE-770 into my computer
Just use a regular printer type cable. On newer models, they use a regular USB connection so it's easier to use USB keys
