Question about Lexmark X4270 All-In-One InkJet Printer
Scanner Sice ive moved my computer to an different area of the house, i was making sure everthing was back in its place . But i notice that my scanner wont scan anymore . Need directiion to make sure its hooked up correctly. Everything else works
    Novelist:
  • 121 Answers
Most lexmark all in one printers require that the drivers be installed first before plugging it into the USB port. If you were moving it, their could have been a chance it didn't get placed back into the same port it was before the move. To solve this issue, either plug the printer into a different USB port or reinstall the printer. I would try option A first, you will know when its correct when A it prints and B you dont recieve a notice on the screen for a driver request.
Posted on Feb 23, 2009
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Could you help me to operate the scanner., so that I can send docs,
make sure your scanner is working properly and the software has been already installed to the server or computer to access the scanner. this steps can help you to operate the scanner.1. connect the scanner to your PC, mostly scanner now is using USB cable 2. and then turn ON your scanner, place your material to be scanned like you were using photo copier 3.press the scan button to acquire the image 4. then preview the scan, the scanner software should display a preview on your computer screen 5. and now select the scan area in the scanner software 6.next set other options for example set the the color or the resolution of the document 7. then scan the image and save it into your disk make as your new folder. after you save you can now send this document.
Apr 15, 2011 | Office Equipment & Supplies
Where is the ink located at
You can access the cartridge area if you lift the entire scanner unit up. (see image below)
Make sure the printer is on. When the scanner unit is lifted up, the print cartridge carrier moves and stops at the loading position to the center.
If you're going to replace the cartridges, squeeze the tabs on the cartridge lids, and then lift the lids.
Remove the used cartridges and install the new ones and snap the lid closed.
Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Hope this information has been helpful. Thanks.
Nov 23, 2010 | Lexmark X1150 All-In-One InkJet Printer
Copier is blinking l 1. what does that mean?
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Nov 11, 2010 | Sharp AL 1631 Copier
Where do tou install ink
From the Manual:
1 Make sure the printer is on.
2 Lift the printer (scanner unit) until the scanner support keeps it open. The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges. Store them in an air-tight container or dispose of them.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of the cartridges.
NOTICE: Do not touch the gold contact area on the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the printer (scanner unit) until it is closed.
Sep 18, 2010 | Dell A920 InkJet Printer
I am repeatedly getting error code 5010 once I scan any document.
Ok it can be either 2 things: The FIRST is if you have not UNLOCKED the scanner lock switch. The scanner lock switch is a switch that keeps the scanner assembly frozen in place so that when you move your scanner from room to room or apartment to house, the scanner wont freely move around the unit causing it to be dammaged.
To unlock the Scanner lock switch just lift your document cover and look for the swtch on the LEFT hand side of the scanner's glass bed.
SECOND: IF the scanner lock swtich is set at UNLOCK, then your scanner assembly is broken and needs to be replaced. You must then send it to Cannon or any Mulitfunction printer repair place.
I hope this helps you :)
Mar 15, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How do i get my scanner working
Hi
You can first go to add and remove and uninstall printer driver first then reinstall it back who knows it might work
All The Best: Pineworks
Jan 27, 2010 | HP Photosmart C3150 Printer
E-90 error message on Epson CX6000
If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
  1. Turn off the Stylus CX.
  4. Close the scanner and turn the Stylus CX back on.
Also
  5. Close the scanner.
  6. Turn the Stylus CX back on.
Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Clicking nosie from scanner bed on epson cx5800f
I had a similar problem, the scanner bar was stuck to the far left side. Here's how I fixed it:
1)Unplug the printer, disconnect any cables/phone lines to it.
2)Lift up the entire scanner bed housing(you will see the printer ink cartridges).
3)Locate the access patch (approx 1 cm x 1 cm square) along the left edge of the scanner bed housing(this is the side that closes in, next to the keypad buttons).
4)Using a small knife blade, peel off the patch from the corners and edges(it's sticky. Save it, you can stick it back over the hole when you're done).
5)Stick a pen through the access hole, and push the scanner bar to the right, approximately 2-3 inches.
6)Now, close the scanner housing, plug in the printer, and power it on.
It should reset and re-calibrate the scanner bar. If it doesn't, repeat steps 5) and 6) a couple times, until the printer correctly performs calibration. Then, you can put the sticky patch back over the hole, and you're ready to go. Hope this helps!
Jun 28, 2008 | Epson Stylus CX5800F All-In-One InkJet...
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
Lexmark X4270 All-In-One InkJet Printer Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
