Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
On initial set up on SX200, will not initialize ink system
  • 1,800 Answers
Clean the vartridge pins and printer slots and try again.
Posted on Feb 23, 2009
SX200 WILL NOT RECOGNISE NON STD INKS
Check your update settings in the printer software. Turn off any automatic updates from Epson. To get updates, put some old Epson cartridges, good or bad, in while you update. Epson will log on to your printer and kill your non-Epson cartridges during auto updates.
Apr 09, 2015 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
How to disable demo mode lg 55ln5750
On remote Press SMART (with house symbol)
go to
settings then
option then
mode setting then select
home use
(and, if you're feeling really brave, but it's not necessary to do this to remove demo mode
to return to initial settings
SMART
Settings
OPTION
Initial Setting
Deletes all optional settings and returns to initial default mode.
Once initialization is complete, the TV will turn off and on by itself.
If Lock System is activated, a pop-up password prompt will appear.
Do not turn off the power during initialization)
Jun 27, 2014 | Tablets & eReaders
Im having problem with my epson T13 ..with message ink out error..how can i fix it? anuone can help me?tnx a lot
Just use the "Initial setting" on the menu and check the initial setting checkbox and input the printer's serial no. and click perform on the adjustment program by OrThoTaMiNe and turn off your printer. Then turn on, and the ink out error will be gone.
Jan 09, 2011 | Office Equipment & Supplies
Error code: 0xc18a0001
This error code indicates that you have an 'Ink system failure'. The problem is caused by air the ink feed tubes. If you either use all of the ink down to 0% or you use poorly refilled ink cartridges it can cause the printer to **** air into the feed tubes instead of ink. We have a step by step guide to purge the feed tubes of air on our site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/ There are 2 different versions of the procedure find the one for your type printer and follow the guide and within about 10 minutes you will be printing again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
Message states: the following ink cartridges cannot be used after device intialization, and must be replaced
Try the following steps to resolve the issue,
1.) Press & hold the * key
2.) press the # key & release both the keys.
3.) Display should say Enter Special Key Combo - Press & release in sequence 1,2 & 3 buttons.
4.) Press and release the right arrow button (or the right arrow icon on touch screen displays) to look for the System Configuration Menu then press OK.
5.) Press and release the right arrow until the Ink Initialization status is displayed.
6.) Press and release the OK button.
7.) Display should say Ink Initialization status: Clear. Press OK to set it.
8.) Press and release the OK button ONCE. (This is very important; do not press the OK button for a second time).
9.) Press the cancel button three times to leave the support menu.
10.) Unplug the unit from the power supply and wait 10 seconds.
11.) Plug in the unit, Follow the on-screen instructions, the unit will initiate the initialization cycle.
Thanks,
Fame..
Oct 23, 2009 | HP Photosmart C6280 Printer
Had a problem with HP Photosmart C5180 All in One says cartridge cannot be used after initialization. Cannot find telephone number to ring HP in Ireland for support. This happens every time. I just had a...
Introductory cartridges come with the printer and carry special ink formulations intended for printer initialization. During initialization, inks in the introductory cartridges mix with inks in the printer to create a normal ink formulation. After initialization, introductory cartridges can be used in any compatible printer. However, if introductory cartridges that have not been through initialization are installed in a printer that has already been initialized, the printer cannot print
If the issue persists, perform these steps
try the cleaning steps advised in this link...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709715&cc=us&lc=en&dlc=en&product=1153481
Remvoe all Cartridges, disconnect the printer from the computer and connect it to the direct wall outlet and Reset your Printer to initial factory default settings:-
* Remove the power cord from the back of the product.
* Press and hold down the OK and Help buttons at the same time.
* While still holding the buttons down, plug the power cord into the back of the product.
If the issue persists, perform these steps.
1. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
3. Let the Printer power up again and give it time to go through all of its process.
Sep 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Cannot install cartridges to initialize set-up
take it off the tape in the ink cartridge maybe work
Dec 27, 2008 | HP Office Equipment & Supplies
Just bought an HP Photosmart C7280 and am going thru initial set up. Have got to the stage where insert paper which should then run trial page before i then move onto the wi fi set up Unfortunately the...
Where did you buy the printer? Was it new? If you bought it from ebay, the seller has provided a new set of initialisation inks with a used printer. These inks only work with a printer which is brand new and completely unused. They mix with ink already in the system on first use and they cannot be used with another printer and cannot be used in a printer which has already gone through the initialisation process. There is however a work around. Let me know if you need it
Nov 30, 2008 | HP Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
