Question about Nikon Nikomat FT 35mm SLR Camera
Shutter will not advance the film or allow for a picture to be ta
Shutter release button appears to be locked
    Problem Solver:
  • 17 Answers
This will need servicing for the factory oil used for lubracation is dried up. When a camera is 20 years and older the oils contain solvent which evaporates turning the oil into a tar like substance. That causes the mechcanisums to lock up
Posted on Mar 07, 2009
I just bought a nice used Mamiya twin lens C3 but the shutter is locked up. There is a small metal piece holding the shutter release from moving. Not sure how to un-lock, seams to be a safety device of...
The vertical shutter sliding lever gets locked if the film doesn't get advanced to the next frame, and the mode selector is set for single exposure. You can't trip the shutter unless you have film in the camera and you forward the film to the next frame. That should allow you to release the shutter with the sliding lever.
Mar 17, 2014 | Mamiya Cameras
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Film Advance Lever and Shutter Curtain
If the film advance lever is "flopping" back and forth, the problem is most likely a jammed advance mechanism inside. The shutter is cocked *mechanically* and released the same way--no battery power is needed. One old trick you could try to release things is to push the rewind button on the bottom of the camera.*sometimes* it will free up the mechanism enough to unjam.
Sep 17, 2009 | Vivitar V3800N 35mm SLR Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Film advance lever wont move. Shutter button does not register.
the self timer may be the issue. the self timer if not all the way released will not allow you to advance to the next frame :( i sometimes have to push it back to the start position
Nov 13, 2008 | Photography
Film advance
I removed the advance lever cover as suggested and tightened the screw. This did not solve the issue. However, I then realized the film rewind button on the bottom of the camera was stuck on the "in" position. I could not get it to release which meant I could not advance the film lever to free up the shutter. To solve this issue I removed the bottom cover from the camera (taking out the 3 small screws) and then pulled the advance lever button all the way to the right. This released the button that had been stuck in and allowed me to advance the film lever properly again and take more pictures. Hope this helps!
Jul 14, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
The film won't advance
Look on the shutter release button, there is a lock switch on bottom of the button. turn it toward the prism.
Jul 08, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
When we advance film, it takes a picture
The problem is usually caused by a dirty release magnet. I can tell you how to fix it if you are handy with small tools
Feb 03, 2008 | Canon EOS-AE-1 35mm SLR Camera
Film won't advance
Perhaps you've already solved the mystery. There are 2 parts to the back of that camera, the film back + the part that it slips onto. And they have little safety latches/pins that couple in order to advance the film & release the shutter. I'm sure those just aren't in the right place. Here in Los Angeles you could take it to any major camera store or repair shop & they've help you out.
Mar 06, 2007 | Mamiya RB67 Pro SD Medium Format Camera
Nikon Nikomat FT 35mm SLR Camera Logo
88 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
