Question about Compaq Presario SR1030NX (DW256A#ABA) PC Desktop
Compaq Presario Wont Boot
I thought the power supply went out so i got a new power supply.but when i plug it up it wont boot at all.cpu fan tries to come on but only spins for a slight second.if i unplug the 4 way connector(2 yellow&2black wires)comp turns on but no pc beep or screen,also noticed no power to my cd-rom,have tried 3 diff. power supply.when that 4 way connect is unpluged is that why i have no power to my cd-rom or hdd
  • 121 Answers
Hi, my name is ArmyMason, hate to tell you this, but it sounds as if you have a bad Processor. Did you recently experience a bad storm with lightning? Was their a lot of dust on the fan? Lightning could have struck the computer and killed the processor or excessive overheating of the processor could have also been the case. If it was a lightning strike I would contact the insurance agency and have them replace your computer. Reason I think its the processor is because you don't recieve any post and the fan spins for a second and then shuts off.
Posted on Feb 23, 2009
Why compaq presario SR3270nx won't boot but fan runs?
Hello There "A"
Usually PCs that won't boot its for any of these reasons:
1) Voltage on outlet check this*
2) bad Power Supply.
3) bad RAM
4) any near CPU capacitors, on the motherboard.*
May 04, 2014 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
Compaq Presario g62-225nr wont boot
check the ram card. also the battery on the mother board if the are fine then the mother board may have gone.
Sep 21, 2013 | Compaq Computers & Internet
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Compaq presario sr2150nx ata 100 motherboard fan plug
The CPU fan is being detected, but there is a problem with compatability or there is a fault in the fan it's self. Have you tried your original fan?
Mar 10, 2012 | HP Compaq Presario SR2150NX PC Desktop
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
Laptop wont stay on longer than approx 3 seconds. How do I check the switch?
if the switch at least starts the laptop.. then it is not the switch
check that you can boot the pc with the battery pulled out of the laptop and the power supply plugged in...
if this works then you need a new battery
if this does not work.... then the motherboard or the power adapter plug maybe the issue.. is the plug on the side of the laptop solid... or sloppy fitting..
if solid then the motherboard cpu and memory are the suspected components next..
is there beep noises during boot for the three seconds that occur???
Sep 28, 2009 | Compaq Presario X6000 Notebook
Compaq presario c300 wont turn on at all
Looks like a bad motherboard ,have you tried another power adapter the one that connects to the wall socket.
The motherboard could cost over $100 ,chepaer on Ebay or you could take it to a Compaq/HP service center and ask for a quote on the repair.
May 13, 2009 | HP Compaq Motherboard
My Compaq Presario 700 note book is dead
It's possible your battery is dead. Or your cpu fan may be dead which will cause it to shut down. Try holding down the key for your model that will let it boot into safe mode. This will at least narrow down a software problem. It doesn't mean that you have no OS just because you don't see it! You may also have a bad power supply.
If you can get a bootable OS cd or restore disk for your system see if it will let you boot up.
Dec 08, 2008 | Computers & Internet
Wont start up
my wife has a presario that had a similar problem - it would boot up, then immediately shut down. I took off the side plate and blew off some of the dust inside. that worked for a couple of days then the symptoms returned. I took it apart again but this time I removed the cpu fan and the cpu heat sink. I cleaned all the **** off the fan and the heat sink and replaced it. this time it stayed on. I checked out the power supply. compaq installed a very cheap power supply - only 250 watts. a replacement power supply for the same machine but with an output of 300 watts is available. as soon as I can scrape up the change, I'm gonna change the PS
Jun 11, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario SR1030NX (DW256A#ABA) PC Desktop Logo
256 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
