Question about Generac Electrical Supplies
Quietsource 25kw Staring problem In auto mode or manual
Quietsource 25kw Staring problem. In auto mode timer tries to start for weekly start up or manual mode when start button is depressed the engine starter engages for aprox 2 sec and stops and then low battery light comes on. Battery is fully charged, passed load test and 13.49 at battery so the charger must be working If start button is connected to starter solenoid or genset starter contactor engine will crank for ever.swaped RL1 and RL2 made no differance Has been starting for 3 years in auto for either utility loss or weekly exercise cycle
  • 169 Answers
Sounds like the you have no spark since when you force the engine to crank it never fires. The low battery light come on because the 2 sec of cranking lets the voltage get lower than the alarm threshold.
I'd connect a spark tester to either of the plugs and try a manual start, if you see sparks replace the plugs, if you get no sparks then you've got to troubleshoot the ignition modules and the kill wire that comes from them.
Regards,
Carl
Posted on Mar 01, 2009
Problem of Utilitech digital 8 outlet power strip timer
Copy following link to identify exact timer, and download possible manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
With this particular timer, press MODE and PRG button to clear timer programming.
When programming is complete, press CLK button to enter current time setting and end programming.
Then press Mode button until Auto indicator displays.
Make sure current time is correct, and that correct am-pm selected.
Make sure that on-and-off programs are set for same days-of-week, or conflict will cause timer to work erratically.
If timer is defect, buy another timer at Lowes and return defect in new package.
Oct 22, 2012 | Hardware & Accessories
I have the timer programmed but what mode should it be in Off, Auto or Random? I had it in Auto but the timer did not start at 10 am as programmed! Help!
HB88RC is discontinued timer, replaced by 2-outlet HB800RCL or 1-outlet HB800RCH.
Timer functions should work in AUTO.
Try resetting timer by removing AA battery, reinstall fresh battery, and then reprogram timer.
When programming is finished, press clock button and timer should be in AUTO mode and current time displayed.
If you want to change mode, then press mode button. When exiting mode, press clock button and timer should be back in AUTO mode.
If functionality does not restore, then timer has gone bad.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://waterheatertimer.org/pdf/hb88rc.pdf
Jul 05, 2011 | Intermatic HB88RC Outdoor Timer
I am trying to st the timer to turn on at 5PM and turn off at 11PM.
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
HB88RC programming Instructions:
Install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 5pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
Dec 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
Have the timer set on Auto but lights are not on during the ON period. Also do I need to set times for all 7 periods?
No, you do not need to set all 7 timer events.
When event1 ON and event1 OFF are set, press CLOCK button to exit programming and save programs. Or press PROGRAM button and move to event2 ON and event2 OFF. Exit programming any time by pressing clock button.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
That being said, if events conflict with each other, timer will not operate.
For example event1 ON FR at 7pm and event1 OFF all-days at 11pm.
The days have to match for on-off times.
Another example event1 ON FR at 7pm and event1 OFF FR 11pm, but event2 ON all days 8pm event2 OFF all days 10pm. This overlap will cause timer to skip programs.
If timer is being used in random mode, timer programs cannot be closer than 1/2 hour apart.
When programming is done, press clock button to display current time.
Timer should be ready to go.
Manual is fuzzy at this point, and does not specifically say, but it appears that you only press MODE button when you want to set another mode beside auto.
I e-mailed Intermatic last week about this unclear spot because several folks are writing in about this timer not going into correct MODE after programs are set.
MODE must be set to automatic
Press MODE button once for manual override function
Press MODE again and RDM displays for random >> this is for lights turning on randomly when on vacation.
Press MODE button third time, and AUTO shows on display >> you want timer in AUTO for timer programs to operate.
Here's the trick ... after setting MODE to auto, press clock button to display current time
If timer will not enter AUTO, then timer is defective.
If Intermatic sends response that is pertinent to your question, I will post again on this thread.
Add a comment any time, and I will respond.
Dec 10, 2010 | Intermatic HB88RC - 7-Day Programmable...
I have a GE Heavy Duty Digital Timer product # 15117. It also says it is a Jasco Product. I am having a problem getting the clock function to work. I can set the time yet I do know see where there is an...
My auto function on my GE outdoor timer didn't work orginally. So, I programmed the "on" time to be 5 minutes from the current time (10:15 p.m.), and the "off" time to be the time I wanted (10:30 p.m.). Then I put it on automatic and waited for 10:15 p.m. to arrive. It turned on. Then, I set the "on" time to 5:30 p.m. and it works fine now. Apparently, it has to cycle through the "on" time in order to activate the auto function.
Dec 10, 2010 | Garden
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Generac gardian model:005885-0 running rough
Check the spark plugs, ignition coil etc and try to start it manually.
Jun 15, 2010 | Generac Guardian Quietsource 25,000 Watt...
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
Electrical Supplies Logo
442 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
