Question about Troy WindConnect With WindPort PC Card (WNDCMB-001) Print Server
Troy Windconnect printserver has stopped working
I have been using a parallel bluetooth printserver for some time now. After my notebook had a problem and the mainboard has been replaced my troy printserver doesn't work any more. The adapter has serial no.722315. When I connect the power to the adapter the activity and link led blink for a little while and then stop. Than when I connect the adapter to my HP Laserjet 4 nothing seems to work. Pressing the testbutton gives no reaction. The bluetooth drivers on my notebook work, I can connect trough bluetooth to my mobile phone.
Please tell me what to do to get the adapter working again.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
Charm sonic wireless receiver ,pair the device to the first phone,after pair successfully,turn off the wireless function of the first phone,the device will enter pairing mode again,pair the device to the second phone,after pair successfully,turn off the wireless function of the second phone .tun on the wireless function of the first phone,select the "LinK-BT06" and click "connect".turn on the wireless function of the second phone ,select the "LinK-BT06" and click "connect".two phones will both connect the wireless receiver transmitter at the same time.Rang up 30 feet. Amazon com Charm sonic Portable Bluetooth 4 1 Receiver Wireless Multipoint...
Posted on Nov 24, 2016
Due to tolerances in manufacturing, some Bluetooth-adapters/receivers do not stick to the Bluetooth-standards exactly. If this only applies for one adapter/receiver in a pair everything works fine nevertheless. But if both do not stick to the standard, they might not be able to work together, although both would work with a standard-conform third one.
Before your mainboard was replaced, only your printserver was not exactly standard-conform. Now with a new mainboard (and therfore a new Bluetooth-adapter on it) just by accident your Bluetooth-adapter does not confirm to the standard, too.
If all this is right in your case, the solution would be to buy a Bluetooth-usb-dongle for your notebook and use this instead of the built-in Bluetooth-adapter of your notebook. If this new Bluetooth-usb-dongle confirms to the Bluetooth-standards better than your built-in adapter, this might cure the problem. Since such a Bluetooth-usb-dongle only costs about 10 Dollars, it might be worth a try.
Greetings, Michael
Posted on Oct 24, 2009
My Printer is not printing although the printer status is online. How do I fix it?
If you tell it to print and the item goes into your Que for printing. In that screen click on the printer tab... In the drop down verify that the "Use Printer OffLine" does NOT have a check mark next to it.
Dec 30, 2013 | Zebra LP 2844 Thermal Printer
I can't get my computer running windows 7 to recognize the printer
Z6M+ printer doesn't have USB port, how do you connect this printer to Win 7 PC? if you are using parallel / serial converter to USB then good luck. Ideally to get zebra external printserver and connect the printer through the network.
Sep 25, 2013 | Zebra Z6M Plus Thermal Label Printer
Setup stops at printserver will connect to your wireless network
hi
thank you for using Fxiya
go to folowing link you will find complet stup for Linksys printserver
http://www.ehow.com/how_5396340_set-vista-vista-windows-linux.html
May 15, 2010 | Linksys WPSM54G Print Server
I need to add network to 2844 printer currently USB/Serial
You need to buy the zebranet PS2 print server
P/N G46692 External PrintServer II. It will plug into the parallel port. they just stoped making them but they are still for sale at zebra resellers. here is one at random from google
resize?sq=80&uid=1127727233 ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II
more at ZDTronic.com
ZDTronic.com $160.50
  • product
ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II $160.50 at ZDTronic.com
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
Lexmark 640 printers will not print after network security audit.
So you think the scan from the Auditors software jammed the port on the Printserver? Are your printservers PC's that spool the print jobs and then send them to the printer or are the printserver devices? How is you printserver connected to your printer? (ie parallel, USB, COM)
Jun 10, 2009 | Lexmark Z640 InkJet Printer
Printing from 2 differant computers.
At the same time,,no,u have to either use the parralel port or usb at one point of time
this printer was actually launched when the transition just started,,usb printers were new and the parrallel printers were already in use..so its like a backup,,if parrallel port on ur comp doesnt work,,then use the usb
best of luck,,giv a good rating,,keep me posted
May 19, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Troy WindConnect With WindPort PC Card (WNDCMB-001) Print Server Logo
227 people viewed this question
Top Troy Computers & Internet Experts
David Payne
David Payne
Are you a Troy Computer and Internet Expert? Answer questions, earn points and help others
