Question about Texas Instruments TI-84 Plus Calculator
TI-84 Plus Calculator will not turn on, says ram is cleared
My TI-84 Plus Calculator is not working. I have tried new batteries, other people's batteries, pretty much everything. When my calculator does turn on, the screen reads "TI-84 Plus 2.21 RAM Cleared" and then quickly shuts off. I am stumped, and really need some help.
  • jacklin-c Feb 25, 2009
    My calculator is doing the same thing! I was using it in class and then all of a sudden it quit. I have tried to put new batteries in and it won't work so I kept taking the ones I had in and out and sometimes it will pop up and say "TI-84 Plus 2.40 RAM Cleared."
  • Anonymous Mar 11, 2009
    my calculator isnt working at all and i don't know what to do.I have the exact problem the user before me does....help me please!!!
  • 21 Answers
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Posted on Mar 02, 2009
My TI-84 is freezing on a screen that says RAM cleared. Ive tryed putting in new batteries and back up batteries
I had this problem with my TI-89. Try taking out all batteries (including backup) for a good half hour to an hour. It fixed my calculator.
Jun 06, 2011 | Texas Instruments TI-84 Plus Calculator
My ti-84 plus it does not respond to the function + or - OR other function, & it come up to display very slow ,slow. thanks
Hi xvbanh,
You need to free up some memory. Try clearing your RAM. Your calculator should operate properly afterward.
Go to [2nd] [MEM] [7] [1] [2]
If your calculator still won't let you delete the RAM memory try the procedure below.
Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
reinsert the AAA battery and then turn the calculator on. The calculator should display the
message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
Jan 06, 2011 | Texas Instruments TI-84 Plus Silver...
Everytime I turn on my TI-84 Plus Silver, it stays on for 2 seconds, then shuts off on its own. What can fix this? Other details: When it turns on, sometimes it displays Ans+
Hi mixedgamer12,
The process below should reset your Ti84 plus calculator. If you do this process your RAM memory will be cleared and, you will have to re-install the Ti84 plus calculator's OS.
  1. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
  2. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
    "Waiting...Please install calculator software now". Follow the instructions for the
    TI-83 family or TI-84 Plus family to reinstall the calculator operating system in step 3. If the calculator still won't turn on connect the calculator to the computer and, open Ti Connect. Next, open Device Explorer. Is the calculator asking to be installed? Can you go into Device Explorer?
  3. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator if you haven't already.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  5. If the above process did not work to turn your calculator on, try re-doing the above process. Next time extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Dec 31, 2010 | Texas Instruments TI-84 Plus Silver...
RAM CLEARED?
The most likely reason is that the backup battery is drained. Change the backup battery. When you get the Ram Cleared message, just press [CLEAR] to erase the message and start using the calculator.
Hope it helps.
Oct 28, 2009 | Texas Instruments TI-84 Plus Calculator
My TI-84 Plus Silver edition will not turn on. I have tried new batteries and everything, but it just does not turn on. Is there a way to reset it or something although the calculator does not turn on?
Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 21, 2009 | Texas Instruments TI-84 Plus Silver...
TI 84 won't turn on. New batteries installed. TI Connect recognizes device and I installed new OS. Brightness is not the issue. Any suggestions? This is one of student's calculators. Thank you.
Sorry, answer was posted as a clarification request.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
I accidentally pressed down for too long on my ti-84 plus calculator and i think it locked itself. how can i turn it back on? I NEED it for school!
From TI FAQs:
What troubleshooting can I try if the TI graphing calculator will not turn on?
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 24, 2009 | Texas Instruments TI-84 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
2,454 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
