Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell Bissell 2X™ Proheat Extractor-Cleaner
I have this machine but the brushes do not always work. It sucks up about 50% of the moisture but there is no action with the brushes.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
etyu
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
How can I operate the Bissell PROheat 2X carpet/upholstery cleaner without instructions?
Your solenoid that activates the hand unit is most likely burned up. Bissell 2X machines generally last 4 to 6 uses and a solenoid burns up. This is the only machine that we do not offer repair service for in my store. It is a terribly poor quality design.
BTW, the brushes aren't supposed to turn when the machine is in the upright position.
Sep 18, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have borrowed a bissell proheat 2x from a friend and she did not have a manual. I cannot get the brushes to turn.
The User Guide for the Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner is available here:
http://canada.bissell.com/images/UserGuides/9500_107.pdf
Note that the brushes only turn when the unit is reclined using the detent pedal.
If machine has been jammed the internal circuit breaker may have been tripped. Unplug machine from power source, remove object or blockage and then plug machine back in to power source to reset breaker.
More seriously the drive belts may have become worn or have broke or a brush may have become detached; refer to page 18 for instructions on how to replace belts and brush rolls.
More information including a video and replacement parts can be found here by selecting the tabs across the screen below the picture of the machine.
http://canada.bissell.com/Products/p/9500/ak/more+info/Product.aspx
Apr 02, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not sucking up water off carpet
heatman101
fgqwe
Apr 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
May 30, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
85 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
