Question about Gestetner DSm618 All-In-One Printer
Hi i have problems with my 7502 gestetner nrg photocopier
I have a large capacity tray and the standard tray (tray1). when i make copies and the LCT is selected everything is fine. if i choose tha paper from tray 1 tha machine jam the paper before gets into the fuser! i need help? its very strange. everything works correctly with lct and the paper stacks when i use the standard tray1 A4
  • 1 more comment
  • florosel May 09, 2009
    finally the proble eas very big! it was the registration motor. and also the developer unit had problems, developer was falling out of unit! i fixed it.
  • Bernard D'Souza May 11, 2010
    is the paper size setting and direction(landscape / portrait )
    any problems with other trays ?
    how many copies has the machine done?
    how good are the feed rollers?
  • Joseph Micallef May 11, 2010
    If you select paper trays 2 or 3, the copier works fine?
    It jams only when using tray 1?
    New Friend:
  • 103 Answers
Please check the paper orientation in the tray using the green nubs in the tray and also ,
press the counter key and select system setings
tap on the tray settings and then select the paper size and orientation u prefer and press okay and then tou are tyhan
Besty of luck.
Posted on May 25, 2014
  • 32 Answers
This sounds like a paper size issue. Check your papersize and oriontation in the tray(green selector font right or back left of tray) and check paper settings under the user tools menu for tray 1. let me know if that works, so we can trouble shoot.
Posted on May 08, 2010
How to clear c-0210 on bizhub c203
Lower Large Capacity Tray-LCT lift up motor failure..
Check any paper jam at rear side of Tray.
check the plate lift up wire and contacts.
if not
then need to replace Lift-up motor
Nov 15, 2016 | Konica Minolta bizhub Office Equipment &...
Gestetner 6123 paper jaming feeding section copy printer
nrg 6123 copy printer after make stencil line on copy soulition
Jun 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
Problem with the Konica Minolta bizhub C450P Laser Printer Bizhub C450 error (C-0212) , HOW TO FIX IT?? PLEASE GIVE ME THE FIX STEP!! TKS!!!!!
This code is for LCT (Large Capacity Tray) lock release failure. This means there is a problem with the LCT, usually the large paper drawer at the bottom. This code is usually reset by opening then closing the front door. Sometimes turning off then on the main power switch on the right side will clear it. Try releasing the LCT and get it open. Then check the paper in the tray. Most of the time when there are problems with these LCT's it is because too much paper has been loaded or it has been loaded improperly. If you get it open, remove all paper. Then load smaller amounts of paper at a time to insure that it is loaded perfectly. Only load the tray half full at first and then close the drawer and allow it to lift. Then make a copy from that drawer to be sure it feeds paper. Then release the drawer again and finish loading if you want. If you continue to have the code then you can leave the drawer open an inch or so to de-activate it so you can still use the printer from the other drawers until you can get a technician out ot service it.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 16, 2011 | Konica Minolta bizhub C450P Laser Printer
BCU (Base Engine Control Unit) LCT (Large Capacity Tray), Communication/Timeout Error
During Communication with the LCT, the BCU recieved a break(low) signal.
Possible Cause:
Serial line connection unstable.
External Noise on line.
Jan 28, 2011 | Ricoh Office Equipment & Supplies
Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
Oct 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Repeating lines on the same page position for Gestetner 7502?
check and clean your optics unit/ scanner unit lamp and mirror
Aug 27, 2010 | Gestetner 7502 Digital Imaging System...
We have a Konica Minolta Bizhub 350 that is reporting a malfunction-error code C-0001. What is the problem?
C-0001 indicates a "LCT Communication Failure" . LCT stands for Large Capacity Tray. Your machine may have a large tray installed on the bottom. If turning off and unplugging your machine does not solve the problem there may be a loose connection between the tray and the machine. You would have to remove the back cover of the LCT to check the connection, If you do this be sure to unplug the machine from the wall.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Drawer 3 won't open
Drawer 3 is LCT, Large Capacity Tray. if the LCT is not opening, then perform following steps to get rid of this problem. 1-Press the LCT or 3rd tray (large cabinet) inward, and wait for a will see that Tray will open automatically. 2-If the 3rd large tray cabinet is not opening then turn around the machine, at the back side of the 3rd tray, you will see a small hole downside at the back of the tray. Insert screw driver or any pointed thing which can easily go inside.after insertion press the screw driver or thing which you are using inward.the 3rt tray will open.
Mar 02, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Try to reload the copy paper in the LCT staight and even and also make sure the sides of the paper guides are flush against the paper in the paper tray...
May 19, 2008 | Minolta Di3510f Bizhub Copier
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
Feb 04, 2008 | Konica Minolta bizhub C450P Laser Printer
Gestetner DSm618 All-In-One Printer Logo
229 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
