Question about Estate TEDS840JQ Electric Dryer
Have a maytag i replaced the drum wheel and dont remember how the belt goes
  • 350 Answers
Check out this video on Dryer Repair!
jackiaria Mon 02-23-2009 4:07pm EST (USA)
Posted on Feb 23, 2009
Why does myMaytag de212 dryer keeps breaking belt
You must have installed the belt upside down. Remember the flat part must be to the drum not the ribs. Also assure you don't have a twist on the belt as it can invert during the running of the drum. Good Luck
Sep 19, 2014 | Maytag Dryers
Belt on maytag neptune dc dryer needs to be replaced. how do i replace it.
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). This being the case you need to look for screws you can find on the dryer2_bing.gif outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
May 02, 2010 | Maytag Dryers
Belt change on a Maytag DE410
Most of the time these models have screws in the back of the machine on the top lid. You'll need to get over behind the dryer to access this panel. You'll need a "star" type screwdriver (most come in a set). Remove the top lid to expose the drum. The belt will run around the drum and down around the safety cut out switch. This switch is most likely a teflon or plastic wheel that the belt loops around. After installing the belt, replace all of the screws and you're good to go!
Dec 11, 2009 | Dryers
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
Belt Change on a DE313 Maytag Dryer
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Jul 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
MDG4000 maytag neptune dryer.... When you push start, I see it has power by the light that flashes, but the dryer doesn't start. What is wrong? Thanks
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 13, 2009 | Maytag MDG4000 Dryer
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer make very loud 'tumbling', thumping noise but the drum isn't turning. We just replaced the belt and all the wheels and pully's 'appear' to be in good shape. Help.
If you just replaced all that then maybe you dont have the drum put back in there correctly. alternately sometimes the fins on the inside of the drum are not tight and shift and make noise as the drum turns. You tighten those on the outside of the drum. Make sure you put the belt on right.The blower wheel may have worked itself loose. Make sure the belt is on right and the drum was not put back in backwards. Check that, if the other doesnt work. Last but not least I have seen on some Maytag brands the seam on the drum was not welded right and it popped opened/no longer seamed togerther...check that as well.
May 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
How to change belt on maytag model MDE9206AYW dryer
Hi welcome to Fixya
PLEASE RATE ME
May 02, 2009 | Maytag MDE9206 Dryer
Estate TEDS840JQ Electric Dryer Logo
56 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
